How to plot local residuals in pimpleFoam ?
Old   March 21, 2018, 19:22
Default How to plot local residuals in pimpleFoam ?
cyln
cyln is on a distinguished road
I would like to check where the highest local residuals are within my computational domain. How can I make OF calculate the local residuals?
I am using pimpleFoam.
Cheers,
Cyln
cyln is offline   Reply With Quote
Old   June 7, 2018, 22:50
Default Default How to plot local residuals in pimpleFoam ?
abdikerim kurbanaliev
kerim is on a distinguished road
Hi Cyln,
Did you solve your problem?
Kerim
kerim is offline   Reply With Quote
Old   June 7, 2018, 23:15
cyln
Hello Kerim,
Extend editions of OF have a built-in utility called simpleFoamResidual. You can use that to extract local residual data.
Cheers,
Cyln
Old   June 23, 2018, 19:54
I am using openfoam 5. How can I used simpleFoamResidual?
Thanks in advance.
Kerim
Old   June 25, 2018, 05:14
Robert
RobertHB is on a distinguished road
I guess you cant. I at least assume that cyln's answer refers to the OpenFOAM ext. family. But there are several other ways to plot the residuals.
You can use the residual function object. See e.g. here (section 6.3.4, for OF 5.x) and here (for OF v1712). Or plot them with gnuplot (Tutorial).
RobertHB is offline   Reply With Quote
How to use PIMPLE properly? floquation OpenFOAM Running, Solving & CFD 27 August 12, 2024 11:15
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Plot the residuals over all the domain Douglas OpenFOAM Post-Processing 0 June 27, 2017 17:01
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
plot residuals pigna OpenFOAM Running, Solving & CFD 2 December 19, 2014 03:32
