time step independecy
Old   March 15, 2018, 14:54
Default time step independecy
A. Min
alimea is on a distinguished road
​Dear foamers
I have read a paper by the title of:
Method for time-dependent simulations of viscoelastic flows: vortex shedding behind cylinder
​I want to validate my research with this paper, but a problem have been occurred!
When I want to investigate time step independency, I will earn the attached results. it means that for dt=0.001 I can't get good in-dependency from time step in comparison with dt=0.0005. I'm working on viscoelastic fluid with these non-dimension numbers:
Re=100 - El=1 - Betta(etta_p/etta_0)=0.9 - epsilon=0.1 - zetta = 0.01 (EPTT model)
time derivative discretization scheme: CrankNicolson 0.9
In addition I added the energy eqn to my equations (Is it possible that solving this eqn need a very small time step?)
I guess it may because of high betta(the ratio of polymeric viscosity to total viscosity).
Could you please give me your idea?
http://uupload.ir/files/s243_dt_study_cl.jpg
alimea is offline   Reply With Quote
Old   March 16, 2018, 01:03
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
As far as i understand is quite normal what you observe.
You get fluctuations of the drag because of the Strouhal number. This number is more or less time step independent, but the phase changes.
If you lower the time step the drag increases up to dt=0.001. This is the point where your solution gets time step independent.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 16, 2018, 04:05
A. Min
thanks Uwe
if you see the results, if I decrease the dt from 0.001 to 0.0005 I will have 9% change in CD! is it acceptable? is my solution dt independent now?
note: by dt=0.001 I have CFL=0.1 !!
Old   March 16, 2018, 06:58
piu58's Avatar
Uwe Pilz
Time step independent doesn't mean time independent. You have vortex shedding in your simulation which changes the CD periodically. The CD values of 0.001 and 0.0005 are very comparable.
Uwe Pilz
Old   March 16, 2018, 07:02
A. Min
Yes, those are different and I agree that the problem is time dependent. Changing CD with time is showing this dependency.
But when I decrease dt from 0.001 to 0.0005 and I see these 9% change, can I conclude that the problem is dt independent? I think No.
however, thank you for your reply
Old   March 16, 2018, 11:49
piu58's Avatar
Uwe Pilz
I don't understand what you mean. The difference in maximum between dT=0.001 and 0.0005 is around 0.005. Compare this with the 1.4: That is around 0.4%, not more.
Uwe Pilz
Old   March 16, 2018, 12:00
A. Min
I'm sorry, but I think sth is wrong in your comparison. the difference between dt=0.001 and 0.0005 in CD should be compare with the amplitude that is calculated as:
amplitude of oscillation = (CD_max -CD_ Average) = (1.4 - 1.34) = 0.06
so the difference will be:
0.005 / 0.06 *100 = 8.5%
Do you agree with me?
openfoam
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
