interDymFOAM with dynamicRefineFvMesh for DTMB5415 ship |
March 15, 2018, 10:27 |
Luc Bordier
Rep Power: 16 |
I am trying to use dynamicRefineFvMesh within a interDyMFoam computation to refine based on free surface (alpha.water field). When my computation is in PISO mode, the refinement is done but then, pressure number of iteration increase and forces on body become instable such that finally computation crashes. When my computation runs in PIMPLE mode, solver crashes just after the first solve of p_rgh : Code:
PIMPLE: iteration 1 Selected 377308 cells for refinement out of 11056721. Refined from 11056721 to 13697877 cells. Selected 0 split points out of a possible 377308. Execution time for mesh.update() = 18.03 s GAMG: Solving for pcorr, Initial residual = 1, Final residual = 9.78769e-05, No Iterations 74 time step continuity errors : sum local = 5.99048e-12, global = -1.6006e-14, cumulative = 3.108e-10 smoothSolver: Solving for alpha.water, Initial residual = 1.8908e-08, Final residual = 8.08454e-11, No Iterations 1 Phase-1 volume fraction = 0.75008 Min(alpha.water) = -1.56267e-05 Max(alpha.water) = 1.16759 Applying the previous iteration compression flux MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.75008 Min(alpha.water) = -0.00340939 Max(alpha.water) = 1.16624 GAMG: Solving for p_rgh, Initial residual = 0.0813079, Final residual = 0.000809642, No Iterations 7 [13] #0 Foam::error::printStack(Foam::Ostream&)[7] #0 Foam::error::printStack(Foam::Ostream&) addr2line failed [13] #1 Foam::sigFpe::sigHandler(int) addr2line failed [13] #2 ? in "/home/applis/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [7] #1 Foam::sigFpe::sigHandler(int) addr2line failed [13] #3 in "/home/applis/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [7] #2 ?? [13] #4 in "/lib64/libc.so.6" [7] #3 ? [13] #5 ? [13] #6 __libc_start_main? addr2line failed [13] #7 Foam::UOPstream::write(float) Code:
// ************************************************************************* // [bordier@visu: dtmb5415]$ cat system/fvSolution /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1; icAlpha 0; MULESCorr yes; nLimiterIter 10; alphaApplyPrevCorr yes; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; minIter 1; } /* p_rgh { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0.01; };*/ p_rgh { solver GAMG; smoother DIC; tolerance 1e-7; relTol 0.01; cacheAgglomeration false; }; p_rghFinal { $p_rgh; relTol 0; } "pcorr.*" { $p_rghFinal; relTol 0.0001; } "(U|k|omega).*" { solver smoothSolver; smoother symGaussSeidel; nSweeps 1; tolerance 1e-7; relTol 0.1; minIter 1; }; } PIMPLE { momentumPredictor no; nOuterCorrectors 25; nCorrectors 2; //2 nNonOrthogonalCorrectors 0; maxCo 15; maxAlphaCo 5; rDeltaTSmoothingCoeff 0.05; rDeltaTDampingCoeff 0.5; nAlphaSpreadIter 0; nAlphaSweepIter 0; maxDeltaT 0.005; residualControl { p_rgh { relTol 0; tolerance 5e-5; } U { relTol 0; tolerance 1e-4; } } } relaxationFactors { fields { p_rgh 0.4; p_rghFinal 0.4; } equations { U 0.6; UFinal 0.6; } } cache { grad(U); } // ************************************************************************* // Code:
dynamicRefineFvMeshCoeffs { // How often to refine refineInterval 5; // Field to be refinement on field alpha.water; // Refine field inbetween lower..upper lowerRefineLevel 0.001; upperRefineLevel 0.999; // If value < unrefineLevel unrefine unrefineLevel 10; // Have slower than 2:1 refinement nBufferLayers 2; // Refine cells only up to maxRefinement levels maxRefinement 1; // Stop refinement if maxCells reached maxCells 30000000; // Flux field and corresponding velocity field. Fluxes on changed // faces get recalculated by interpolating the velocity. Use 'none' // on surfaceScalarFields that do not need to be reinterpolated. correctFluxes ( (phi none) (nHatf none) (rhoPhi none) (alphaPhi none) (ghf none) ("(alphaPhi-flux(alpha.water))" none) ); // Write the refinement level as a volScalarField dumpLevel true; } Any help is appreciated. |
dynamic, interdymfoam, refine, ship |
interDymFoam: the sinking ship smiles | wouter | OpenFOAM Running, Solving & CFD | 10 | March 15, 2021 18:24 |
Full-scale ship case with velocity using interDyMFoam show unrealistic trim angle!! | lil_star | OpenFOAM | 0 | December 4, 2017 13:00 |
Long simulation time of interFoam and interDyMFoam; ship hull simulation | Mueye | OpenFOAM Running, Solving & CFD | 0 | December 7, 2016 03:13 |
Problem with p_rgh with interDyMFoam in a ship roll decay test | karmo | OpenFOAM Running, Solving & CFD | 1 | August 23, 2012 17:07 |
OpenFOAM15dev interDyMFoam problem using dynamicRefineFvMesh | eberberovic | OpenFOAM Bugs | 6 | January 14, 2010 05:18 |
