March 14, 2018, 07:25 |
Foam fatal error:
L S
Rep Power: 10 |
Hi, I am trying to compile a new solver named phaseChangeHeatFoam with Dynamic Mesh, which i named phaseChangeHeatDyMFoam.
But, i got this error... How can I get rid of this error? Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicRefineFvMesh Reading field p_rgh Reading field T Reading field alpha1 Reading field U Reading/calculating face flux field phi Creating phaseChangeTwoPhaseMixture Selecting phaseChange model Hardt Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading g Reading hRef Calculating field g.h No finite volume options present Creating field kinetic energy K PIMPLE: Operating solver in PISO mode time step continuity errors : sum local = 2.3774014e-11, global = -2.3711534e-20, cumulative = -2.3711534e-20 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 1.7372879e-06, No Iterations 21 time step continuity errors : sum local = 4.1428539e-17, global = -2.7612587e-19, cumulative = -2.998374e-19 Courant Number mean: 0.017258837 max: 0.020827511 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 0.017087957 max: 0.020621298 deltaT = 1.1764706e-06 Time = 1.17647e-06 Selected 6000 cells for refinement out of 24750. Refined from 24750 to 66750 cells. Selected 0 split points out of a possible 6000. Execution time for mesh.update() = 0.57 s time step continuity errors : sum local = 0.016933131, global = 2.8931099e-13, cumulative = 2.8931069e-13 --> FOAM FATAL ERROR: field does not correspond to level 0 sizes: field = 66750 level = 24750 From function void GAMGAgglomeration::restrictField(Field<Type>& cf, const Field<Type>& ff, const label fineLevelIndex) const in file lnInclude/GAMGAgglomerationTemplates.C at line 47. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::GAMGAgglomeration::restrictField<double>(Foa m::Field<double>&, Foam::Field<double> const&, int) const at ??:? #3 Foam::GAMGSolver::agglomerateMatrix(int) at ??:? #4 Foam::GAMGSolver::GAMGSolver(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:? #5 Foam::GAMGPreconditioner::GAMGPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) at ??:? #6 Foam::lduMatrix:reconditioner::addsymMatrixConst ructorToTable<Foam::GAMGPreconditioner>::New(Foam: :lduMatrix::solver const&, Foam::dictionary const&) at ??:? #7 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) at ??:? #8 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #9 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #10 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #11 Foam::fvMatrix<double>::solve() at ??:? #12 at ??:? #13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #14 at ??:? Aborted (core dumped) |
interdymfoam, openfoam, phasechangeheatfoam. |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
