Limited versions of schemes that are already TVD?
Old   March 10, 2018, 00:04
Default Limited versions of schemes that are already TVD?
Thomas Oliveira
t.oliveira is on a distinguished road
Dear Foamers,
OpenFOAM offers schemes for strictly bounded versions "for the following schemes: limitedLinear, vanLeer, Gamma, limitedCubic, MUSCL", that is, one can use limitedLimitedLinear, limitedVanLeer, limitedGamma, limitedLimitedCubic, limitedMUSCL.
However, aren't the schemes vanLeer, Gamma, limitedCubic and MUSCL already bounded themselves (and limitedLinear if used with coefficient 1), because they are TVD?
Could you please tell me if I am missing something here?
Best regards,
Thomas Oliveira
Supporting info:
Gamma
"High resolution NVD differencing scheme for arbitrarily unstructured meshes". H Jasak, HG Weller, AD Gosman. International journal for numerical methods in fluids 31 (2), 431-449
limitedCubic
Comment "// Limit the limiter to obey the TVD constraint" in src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/limitedCubic/limitedCubic.H
limitedLinear 1
return max(min(twoByk_*r, 1), 0); // in src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/limitedLinear/limitedLinear.H
MUSCL
return max(min(min(2*r, 0.5*r + 0.5), 2), 0); // in src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/MUSCL/MUSCL.H
vanLeer
return (r + mag(r))/(1 + mag(r)); // in src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/vanLeer/vanLeer.H
t.oliveira is offline   Reply With Quote
Old   March 12, 2018, 03:11
W.T
dybuk is on a distinguished road
These schemes are not olny TVD but also you can specify a physical bounds for values.
For example " limitedLimitedLinear -2 2 1 " corresponds to limitedLinear scheme with coefficient 1 that bound field values between -2 and 2.
dybuk is offline   Reply With Quote
Old   March 12, 2018, 08:09
Thomas Oliveira
Thank you, dybuk.
If I am solving an advection-diffusion problem, the boundary conditions are already within the physical bounds, and the discretization scheme for the convective term is TVD, isn't the solution already guaranteed to be within the physical bounds, without needing to use one of the limited versions of the TVD schemes?
Best regards,
Thomas Oliveira
boundedness, divschemes, flux limiter, tvd
TVD schemes, questions about limitedLinear davibarreira OpenFOAM 31 October 21, 2021 00:05
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
TVD schemes Vino Main CFD Forum 3 September 16, 2013 20:47
TVD schemes: 2 questions Shuo Main CFD Forum 0 August 19, 2008 22:51
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 05:21
