March 7, 2018, 12:56 |
Using more than one AMI region and rotation
Paul Palladium
Rep Power: 10 |
EDIT : Solution found : I put ; at a wrong place. The following dictionary is ok.
Dear Foamer, Do you know the correct syntax for using 2 different rotating AMI region ? For exemple a case with two turbines. I read old posts without finding the answer (I am using OF1712+ and I am not able to find the correct syntax) Multi rotating axes in OpenFOAM https://fr.slideshare.net/fumiyanozaki96/openfoam MRF to solidBodyMotionFvMesh with multiple rotors Multiple AMI rotations not working See box2d_moveDynamicMesh tutorial for the correct dictionary. Faust Last edited by Fauster; March 7, 2018 at 14:45. Reason: Solution found |
AMI Motions: Ramped Rotation Speeds and Nested Sliding Interfaces | lordvon | OpenFOAM Programming & Development | 1 | July 13, 2024 12:27 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 05:23 |
Aligning a region with dfbi motion of body without dfbi superposed rotation | rockydongre | STAR-CCM+ | 2 | July 21, 2014 02:11 |
Trouble with simple AMI case | Horus | OpenFOAM | 0 | February 26, 2013 10:31 |
Apply Rotation Speed of Rotating Region | Joke | Main CFD Forum | 0 | September 19, 2011 10:48 |
