Why Initial residual is not equal to the final residual obtained from the previous it
Old   March 7, 2018, 03:12
Default Why Initial residual is not equal to the final residual obtained from the previous it
ANKUR GARG
ankur_garg is on a distinguished road
Hello, I am working on fvDOM library to simulate a radiation problem. I was just wondering why Initial residual is not equal to the final residual obtained from the previous iteration?
Like if you see if the figure "firstIteration" , we have initial residual as 0.1075 and final residual as 0 for first ray, now in the next iteration initial residual is 0.061662 and final residual as 4.97e-19 for first ray?
Thank you very much.
Regards,
Ankur
Ankur Garg
ankur_garg is offline   Reply With Quote
Old   March 7, 2018, 03:57
akidess's Avatar
Anton Kidess
Counter-question: Why would you expect it *not* to change?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 7, 2018, 10:32
ANKUR GARG
Dear Sir,
Actually the equation, I am trying to solve is quite simple, which is given as:
dI/ds = kappa*(I_b-I);
where kappa is an absorptivity, I is the intensity at certain distance s and I_b is Black body Intensity.
Now, first of all, in one solver iteration itself, it shall give that the ray is converged as the final residual is less than the convergence.
But, if it comes to the next solver iteration, the initial residual should be equal to the final residual obtained from the previous iteration according to the mathematical procedure.
Are you Okay with my Answer?
Ankur Garg
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
