Rep Power: 8 ![]() |
Hey guys I need your help.
I am working on a natural convection case and am looking at a building with openings in the walls and ceiling. The air in the building/room is heaten up by a heat source implemented via fvOptions. So far so good, this works fine. The problem I have is that there is no transport between the air in my room and the air outside of it. Whether U or T seems to change. I don't really know which boundary condition I should set for U at the coupled patches. (Air_to_Umgebung, Umgebung_to_Air) Code:
Air_to_Umgebung { type compressible::turbulentTemperatureCoupledBaffleMixed; value $internalField; Tnbr T; kappaMethod fluidThermo; } Any help or tip is appreciated ![]() Attached a small picture (colouring according to U) Green=air room Blue=air outside Was using noSlip as boundary condition, don't ask me why :/ zeroGradient isn't working either (temperature blows up) |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
[mesh manipulation] Problem with using createPatchDict to define cyclic boundaries | kaszt | OpenFOAM Meshing & Mesh Conversion | 0 | April 1, 2016 21:18 |
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 11:04 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
