rhoPimpleFoam stuck at first field averaging
Old   February 28, 2018, 15:13
Exclamation rhoPimpleFoam stuck at first field averaging
Osman Mirza Demircan
omdemircan is on a distinguished road
Hi Foamers,
I am running an analysis using rhoPimpleFoam in OpenFoam 4.1 and for the first time I have encountered a rather strange problem: the code stops right after writing the first field averaging and doesn't give any errors. It just stays like that, stuck in the iteration.
I have the following log the moment the run gets stuck:
Courant Number mean: 0.02938614 max: 1.000011
deltaT = 8.393111e-07
Time = 0.0001762389
PIMPLE: iteration 1
DILUPBiCGStab:  Solving for Ux, Initial residual = 3.207686e-05, Final residual = 6.313603e-08, No Iterations 1
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.0007017714, Final residual = 2.766591e-08, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 0.00204111, Final residual = 7.322674e-08, No Iterations 1
DILUPBiCGStab:  Solving for e, Initial residual = 7.888769e-05, Final residual = 2.252963e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.001138042, Final residual = 1.867949e-09, No Iterations 1
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 9.460353e-12, global = -1.011288e-14, cumulative = -6.846426e-09
rho max/min : 1.453929 0.9230945
PIMPLE: iteration 2
DILUPBiCGStab:  Solving for Ux, Initial residual = 8.613396e-06, Final residual = 2.036931e-08, No Iterations 1
DILUPBiCGStab:  Solving for Uy, Initial residual = 2.719761e-05, Final residual = 9.958047e-08, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 7.845208e-05, Final residual = 2.66355e-07, No Iterations 1
DILUPBiCGStab:  Solving for e, Initial residual = 7.790488e-05, Final residual = 2.229482e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0004511078, Final residual = 6.413692e-10, No Iterations 1
time step continuity errors : sum local = 3.251614e-12, global = -1.396225e-15, cumulative = -6.846427e-09
rho max/min : 1.453856 0.9231683
DILUPBiCGStab:  Solving for omega, Initial residual = 3.781517e-05, Final residual = 1.050715e-07, No Iterations 1
DILUPBiCGStab:  Solving for k, Initial residual = 5.294397e-05, Final residual = 1.939542e-07, No Iterations 1
PIMPLE: not converged within 2 iterations
ExecutionTime = 39.62 s  ClockTime = 42 s
    functionObjects::MachNo Ma writing field: Ma
    functionObjects::Q Q writing field: Q
fieldAverage fieldAverage write:
    Calculating averages
    Writing average fields
The mesh is unstructured and 3D, I don't know if this has any meaning but I've never had this kind of problem with structured mesh. I am currently working with unstructured tetrahedral grids.
You can find my controlDict in the attachments, thank you.
omdemircan is offline   Reply With Quote
average field, averaging, rhopimplefoam, stop
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 12:54
New Solver error Foam::error::printStack upuli OpenFOAM Running, Solving & CFD 4 May 11, 2018 02:43
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 23:28
Averaging field over a spatial direction fs82 OpenFOAM 10 August 12, 2009 11:44
