Too many iterations causing long simulation time :( |
February 26, 2018, 18:55 |
Shafik Walakaka
Rep Power: 8 |
Hi everyone,
I am trying to simulate a two-phase stratified flow in a pipe. However, my simulations are taking extremely long. It states that it takes 1001 iterations to obtain pressure , does anyone know what could be the cause of this issue? PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.000529543, Final residual = 2.66809e-11, No Iterations 2 Phase-1 volume fraction = 0.517887 Min(alpha.water) = 0 Max(alpha.water) = 1.06837 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.517887 Min(alpha.water) = -8.72144e-07 Max(alpha.water) = 1.06794 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.880426, No Iterations 1001 time step continuity errors : sum local = 0.00204219, global = -2.39327e-05, cumulative = -4.39327e-05 DICPCG: Solving for p_rgh, Initial residual = 0.270516, Final residual = 0.753417, No Iterations 1001 time step continuity errors : sum local = 0.00579181, global = -2.39253e-05, cumulative = -6.7858e-05 DICPCG: Solving for p_rgh, Initial residual = 0.510678, Final residual = 0.1488, No Iterations 1001 time step continuity errors : sum local = 0.00170815, global = -1.19552e-05, cumulative = -7.98132e-05 ExecutionTime = 12.26 s ClockTime = 12 s Regards Shafik |
February 27, 2018, 03:03 |
Uwe Pilz
Rep Power: 15 |
You get such effects if something wrong with your boundary or initial conditions. Or you set up your case in a non physical way.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 27, 2018, 15:52 |
#3 | |
Shafik Walakaka
Rep Power: 8 |
Could you kindly elaborate what you mean by wrong boundary/initial conditions or non physical? Because I am getting accurate results when modelling single phase flow (Unless it is possible to obtain good results with my error). Which is why I am confused, what do you mean by wrong boundary/initial conditions or non physical way? Kind regards Shafik |
February 28, 2018, 02:14 |
Uwe Pilz
Rep Power: 15 |
Good morning,
if yopu take additional effects in to account, the behaviour of the solver may change. Somtimes, it ist more or less a different solver. I see two ways that anybody may help you. Either you reduce the effect you see to the simples thinkable case and report is as an error. Or you describe what is your real problem and which connection to the physical worls it has. May be there are other ways to solve it.
February 28, 2018, 06:41 |
#5 | |
Shafik Walakaka
Rep Power: 8 |
Thank you for your kind reply. I am currently using the interFoam solver which uses the Pimple algorithm. I notice that when I change the deltaT, the number of iterations required for pressure correction to converge reduces! Is there an explanation for this? Regards Shafik |
iterations, openfoam |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
