MRF embedded in another one
Old   February 25, 2018, 07:22
Default MRF embedded in another one
Marco Nicotra
jjokocha is on a distinguished road
Dear all,
I was wondering wheater it is possible to simulate in OpenFoam (steady simulation, no moving meshes) the motion of a rotating component (eg wheel with its spokes) , when its rotational axis (wheel axle) is itself rotating with respect to a fixed frame (eg roll motion around the wheel-ground contact patch).
I found out that this is possible in Ansys Fluent using the "embedded reference frame" feature, which enables a moving reference frame to be referred to another fluid domain which itself is in motion.
Anyone as suggestions?
Thanks in advance
MN
jjokocha is offline   Reply With Quote
moving reference frames, mrf simplefoam, mrf., simple foam, wheels
MRF and topoSet problem- Rotating volume doesn't rotate andreas0209@hotmail.com OpenFOAM 1 April 4, 2021 14:35
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
Possibly serious MRF implementation issue Ali Blues OpenFOAM Bugs 1 December 16, 2015 07:04
MRF setup andreas0209@hotmail.com OpenFOAM Pre-Processing 1 August 6, 2015 10:36
Should an empty MRF zone really induce this much cross-flow? sylvester OpenFOAM 5 November 18, 2010 04:48
