Compressible subsonic 2d airfoil investigation
Old   February 22, 2018, 11:59
Default Compressible subsonic 2d airfoil investigation
Max
happyFoamer is on a distinguished road
Hi Foamer-Community,
I'm trying to simulate an Airfoil 2D with OpenFoam and run into divergence problems. I started with 100 m/s (AoA=2°) and increased the velocity step by step to now 180 m/s. For 200 m/s the simulation crashes after reaching about 800 iterations. The residuals of k and epsilon increase and they are bounded.
I use rhoPimpleFoam and the mesh should be fine. There are no warnings when running checkMesh. As turbulence model kEpsilon is activated. TimeStep is set to 1e-4. I'm running openFoam in a virtualbox.
The domain consists of one disk with one cell thickness. The airfoil is cut out in the center of the disk. So there are 3 boundaries: Airfoil(wall); Farfield(inlet and outlet to produce 360° polars); Symmetry_Plane(front and back side of the disk)
It would be great to get some advices. I tried a lot but nothing succeeded.
Here are some specifications of my case:
fvSolution:
solvers
    "(p)"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0.001;
    "(p)Final"
        $p;
        relTol          0;
    "(rho|U|e)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0.001;
    "(rho|U|e)Final"
        $U;
        relTol          0;
    "(k|nTilda|epsilon)"
        solver          GAMG;
        smoother        DILUGaussSeidel;
        tolerance       1e-08;
        relTol          0.001;
    "(k|nTilda|epsilon)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor   yes;
    transonic           no;
    nOuterCorrectors    50;
    nCorrectors         1;
    nNonOrthogonalCorrectors 0;
    consistent          yes;
    SIMPLErho           yes;
    residualControl
        "(U|k|epsilon)"
            relTol          0;
            tolerance       0.0001;
    turbOnFinalIterOnly no;
relaxationFactors
    fields
        "p.*"           1;
        "rho.*"         1;
    equations
        "U.*"           0.9;
        "(e|h)"         0.7;
        "(k|epsilon|omega).*" 0.8;
thermophysicalProperties:
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        molWeight   28.97;
    thermodynamics
        Cp          1007;
        Hf          0;
    transport
        As          1.458e-06;
        Ts          110.4;
boundaries:
alphat:
dimensions      [1 -1 -1 0 0 0 0];
internalField   uniform 1e-3;
boundaryField
    Airfoil
        type            compressible::alphatWallFunction;
        value           $internalField;
    Symmetry
        type            empty;
    Farfield
        type            calculated;
epsilon:
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 200;
boundaryField
    Airfoil
        type            epsilonWallFunction;
        value           uniform 200;
    Symmetry
    type        empty;
    Farfield
        type            inletOutlet;
        inletValue      uniform 200;
        value           uniform 200;
k:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1;
boundaryField
    Airfoil
        type            kqRWallFunction;
        value           uniform 1;
    Symmetry
    type        empty;
    Farfield
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
p:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1.0e5;
boundaryField
    Airfoil
        type            zeroGradient;
    Symmetry
        type            empty;
    Farfield
        type            fixedValue;
T:
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 288.15;
boundaryField
    Airfoil
        type            zeroGradient;
    Symmetry
    type        empty;
    Farfield
        type            inletOutlet;
        inletValue      $internalField;
U:
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform (99.94 3.49 0);
boundaryField
  Airfoil
    type noSlip;
  Symmetry_Plane
    type empty;
  Farfield
    type freestream;
    freestreamValue uniform (99.939083 3.489950 0);
Error:
[1] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[1] #1  Foam::sigFpe::sigHandler(int) at ??:?
[1] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
[1] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
[1] #5  ? at ??:?
[1] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #7  ? at ??:?
[openfoam-VirtualBox:16350] *** Process received signal ***
[openfoam-VirtualBox:16350] Signal: Floating point exception (8)
[openfoam-VirtualBox:16350] Signal code:  (-6)
[openfoam-VirtualBox:16350] Failing at address: 0x3e800003fde
[openfoam-VirtualBox:16350] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fb0575734b0]
[openfoam-VirtualBox:16350] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fb057573428]
[openfoam-VirtualBox:16350] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fb0575734b0]
[openfoam-VirtualBox:16350] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x184)[0x7fb05cd58de4]
[openfoam-VirtualBox:16350] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fb05cd6865a]
[openfoam-VirtualBox:16350] [ 5] rhoPimpleFoam[0x42ab96]
[openfoam-VirtualBox:16350] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fb05755e830]
[openfoam-VirtualBox:16350] [ 7] rhoPimpleFoam[0x4328f9]
[openfoam-VirtualBox:16350] *** End of error message ***
Thanks a lot in advance! :-)
happyFoamer is offline   Reply With Quote
airfoil 2d, compressible, rhopimplefoam, transient 2d
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
