A simple rotorDiskSource case
Old   February 20, 2018, 13:02
Default A simple actuationDiskSource case
So Anon
redbullah is on a distinguished road
Hello all,
I am pretty new to OpenFOAM and have been playing with the actuationDiskSource function to simulate a wind turbine using pimpleFoam. My case is fairly simple: a rectangular tunnel of 100m in x direction and 10m X 10m cross sectional area in x-y directions. Flow is in +x direction. I am trying to place a single wind turbine in the middle of the tunnel (disk center at <50,5,5>).
After examining the turbineSiting tutorial, two files has caught my attention:
  • system/topoSetDict
  • constant/fvOptions
The settings I have in those files are;
actions
    // actuationDisk1
        name    actuationDisk1CellSet;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (50.5 0 0) (54.8 10 10);
        name    actuationDisk1;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set actuationDisk1CellSet;
disk1
    type            actuationDiskSource;
    fields      (U);
    selectionMode   cellSet;
    cellSet         actuationDisk1;
    diskDir         (-1 0 0);    // Orientation of the disk
    Cp              0.386;
    Ct              0.58;
    diskArea        7.07; // area of radius 1.5m
    upstreamPoint   (50 5 5);
With these settings, I do not see the effect of actuator disk. Any other settings to adjust, or something wrong?
Thanks in advance.
redbullah is offline   Reply With Quote
openfoam, pimplefoam, rotordisksource
Help resolving simple case in buoyantSimpleFoam sturgeon OpenFOAM Running, Solving & CFD 1 November 7, 2017 13:49
Simple case - Thermal Solver sdcpune Main CFD Forum 2 May 26, 2013 22:46
Help Required With Simple Test Case steph79 OpenFOAM Pre-Processing 4 August 3, 2010 08:45
Simple Q. How to complete a Case? W.A. Siemens 3 April 23, 2006 20:41
Need help on simple CFD case. (using CFD-ACE+) Sean Main CFD Forum 1 September 30, 2005 11:05
