multiphaseInterfoam non-constant inlet
Old   February 20, 2018, 04:04
Default multiphaseInterfoam non-constant inlet
kaaja is on a distinguished road
Edit2: Problem solved. See "edit" in the end.
I run multiphaseInterfoam, and I have trouble with the inlet being non-constant (I want it to be constant.)
Here are my alpha-files
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.air;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    //- Set patchGroups for constraint patches
    #includeEtc "caseDicts/setConstraintTypes"
    inlet
        type            alphaContactAngle;
        thetaProperties
            ( freshWater air ) 90 0 0 0
            ( saltWater air ) 90 0 0 0
            ( freshWater saltWater ) 90 0 0 0
        value           uniform 0;
    outlet
        thetaProperties
        value           uniform 0;
        atmosphere
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
    barge
        thetaProperties
        value           uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.freshWater;
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;
    outlet
        type            variableHeightFlowRate;
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
        inletValue      $internalField;
    barge
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.saltWater;
boundaryField
    inlet
        type            fixedValue;
    outlet
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
    barge
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alphas;
boundaryField
    inlet
        type            fixedValue;
    outlet
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
    barge
        type            zeroGradient;
The above gives the following, wanted, distribtion of fluids for timestep 1
However, after several time the above changes, also at the inlet.
I really don't understand the contactAngle functino used in alpha.air above. I have tried with the following alpha.air
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.air;
boundaryField
    inlet
        type            fixedValue;
    outlet
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
    barge
        type            zeroGradient;
With the alpha.air above I get the following error message
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 5.x-197d9d3bf20a
Exec   : multiphaseInterFoam -parallel
Date   : Feb 20 2018
Time   : 08:53:57
Host   : "..."
PID    : 27944
I/O    : uncollated
Case   :...
nProcs : 8
Slaves :
7
"....27945"
"....27946"
"....27947"
"....27948"
"....27949"
"....27950"
"....27951"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Selecting incompressible transport model Newtonian
[1] #0[0] #0    Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[7] [6] #0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&)#0  Foam::error::printStack(Foam::Ostream&) at ??:?
[1] #1  Foam::sigFpe::sigHandler(int) at ??:?
[6] #1  Foam::sigFpe::sigHandler(int) at ??:?
[7] #1  Foam::sigFpe::sigHandler(int) at ??:?
[0] #1  Foam::sigFpe::sigHandler(int) at ??:?
[3] #1  Foam::sigFpe::sigHandler(int) at ??:?
[1] #2  ? at ??:?
[6] #2  ? at ??:?
[7] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[0] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[6] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[3] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[6] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[1] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[0] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[7] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[1] #5  Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
[6] #5  Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
[0] #5  Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
[7] #5  Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
[3] #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[1] #6   at ??:?
[7] #6   at ??:?
[6] #6   at ??:?
[0] #6  ???? at ??:?
[3] #5  Foam::multiphaseMixture::multiphaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/multiphaseInterFoam"
[1] #7  __libc_start_main in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/multiphaseInterFoam"
[6] #7  __libc_start_main in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/multiphaseInterFoam"
[0] #7  __libc_start_main at ??:?
[3] #6   in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/multiphaseInterFoam"
[7] #7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #8   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #8   in "/lib/x86_64-linux-gnu/libc.so.6"
[6] #8  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #8  ?? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/multiphaseInterFoam"
[3] #7  __libc_start_main??[karl-HP-OMEN-Pro-15-Notebook:27945] *** Process received signal ***
[...27945] Signal: Floating point exception (8)
[...:27945] Signal code:  (-6)
[...:27945] Failing at address: 0x3e800006d29
[...:27945] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7f5db443d140]
[...:27945] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f5db443d0bb]
[...:27945] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7f5db443d140]
[...:27945] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x155 in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/multiphaseInterFoam"
[...:27944] *** Process received signal ***
[...:27944] Signal: Floating point exception (8)
[...:27944] Signal code:  (-6)
[...:27944] Failing at address: 0x3e800006d28
[...:27944] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7f00cb829140]
[...:27944] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f00cb8290bb]
[...:27944] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7f00cb829140]
[...:27944] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x)[0x7f5db598ae55]
[...:27945] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x20e)[0x7f5db9e9e3de]
[...:27945] [ 5] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4Foam17multiphaseMixtureC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEE+0x51d)[0x7f5db9e7172d]
[...:27945] [ 6] multiphaseInterFoam(+0x34329)[0x5556335d5329]
[...:27945] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f5db44271c1]
[...:27945] [ 8] multiphaseInterFoam(+0x3a26a)[0x5556335db26a]
[...:27945] *** End of error message ***
155)[0x7f00ccd76e55]
[...:27944] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x20e)[0x7f00d128a3de]
[...:27944] [ 5] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4Foam17multiphaseMixtureC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEE+0x51d)[0x7f00d125d72d]
[...:27944] [ 6] multiphaseInterFoam(+0x34329)[0x558038293329]
[...:27944] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f00cb8131c1]
[...:27944] [ 8] multiphaseInterFoam(+0x3a26a)[0x55803829926a]
[...:27944] *** End of error message ***
[...:27950] *** Process received signal ***
[...:27950] Signal: Floating point exception (8)
[...:27950] Signal code:  (-6)
[...:27950] Failing at address: 0x3e800006d2e
[...:27950] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7feb936ac140]
[...:27950] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7feb936ac0bb]
[...:27950] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7feb936ac140]
[...:27950] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x155)[0x7feb94bf9e55]
[...:27950] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x20e)[0x7feb9910d3de]
[...:27950] [ 5] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4Foam17multiphaseMixtureC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEE+0x51d)[0x7feb990e072d]
[...:27950] [ 6] multiphaseInterFoam(+0x34329)[0x562c0d3ad329]
[...:27950] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7feb936961c1]
[...:27950] [ 8] multiphaseInterFoam(+0x3a26a)[0x562c0d3b326a]
[...:27950] *** End of error message ***
[...:27951] *** Process received signal ***
[...27951] Signal: Floating point exception (8)
[...27951] Signal code:  (-6)
[...27951] Failing at address: 0x3e800006d2f
[...27951] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7f88852f6140]
[...27951] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f88852f60bb]
[...27951] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7f88852f6140]
[...27951] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x155)[0x7f8886843e55]
[...27951] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x20e)[0x7f888ad573de]
[...27951] [ 5] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4Foam17multiphaseMixtureC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEE+0x51d)[0x7f888ad2a72d]
[...27951] [ 6] multiphaseInterFoam(+0x34329)[0x5566b2bd7329]
[...27951] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f88852e01c1]
[...27951] [ 8] multiphaseInterFoam(+0x3a26a)[0x5566b2bdd26a]
[...27951] *** End of error message ***
[3] #8  ?[...27947] *** Process received signal ***
[...27947] Signal: Floating point exception (8)
[...27947] Signal code:  (-6)
[...27947] Failing at address: 0x3e800006d2b
[...27947] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7fa7776e8140]
[...27947] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7fa7776e80bb]
[...27947] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x37140)[0x7fa7776e8140]
[...27947] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x155)[0x7fa778c35e55]
[...27947] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x20e)[0x7fa77d1493de]
[...27947] [ 5] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libmultiphaseInterFoam.so(_ZN4Foam17multiphaseMixtureC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEE+0x51d)[0x7fa77d11c72d]
[...27947] [ 6] multiphaseInterFoam(+0x34329)[0x55bd837b3329]
[...27947] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7fa7776d21c1]
[...27947] [ 8] multiphaseInterFoam(+0x3a26a)[0x55bd837b926a]
[...27947] *** End of error message ***
mpirun noticed that process rank 6 with PID 0 on node ... exited on signal 8 (Floating point exception).
Does anybvody know how to modify the above files to make the distribution of alpha's at the inlet constant?
edit:
In the last version of alpa.air I changed from "internalField uniform 0" to "internalField uniform 1", as shown below, and not the inlet is constant. I think the internalFIeld value has to equal the default value set in setFieldsDict.
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.air;
internalField   uniform 1;
boundaryField
    inlet
        type            fixedValue;
    outlet
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
        value           uniform 1;
    barge
        type            zeroGradient;
kaaja is offline   Reply With Quote
Old   February 21, 2018, 21:13
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Dear kaaja,
Have you solved this problem? I am working on the same problem like you. I want to set the three phases moving from left to right. I use groovybc, but it doesn't work.
Best regards,
Chengan
wangchengan2003 is offline   Reply With Quote
Old   February 22, 2018, 02:50
Chengan,
The Inlet became stable (constant alpha shares) when I did what I wrote in my "edit". So I did not use the contactAngle stuff for alpha.air, but used a alpha.air file that looked very similar to the other alpha-files. Also I made sure that the internalField was 1, not 0. That made it work. Hope that helps!
Old   February 22, 2018, 21:24
chengan.wang
Dear kaaja,
Thank you for your reply. I still have a question. If we want to set the three phases moving from left to right, we still use the following code for all the alpha-files?
inlet
type fixedValue;
Best regards
Chengan
Old   February 23, 2018, 03:04
What I ended up doing is as you say, using the following on all inlets
inlet
        type            fixedValue;
However, the internalField value is not the same in the alpha-files. I use the value "1" for the alpha that is set as the default phase in "setFieldsDict", and the value "0" for internalFIeld in the other alpha-files.
I do not understand this fully myself. It is maybe not necessary to choose internalFIeld "1" for the alpha that is set as default in "setFieldsDict". Maybe it is possible to have internalFIeld "1" for another alpa than the alpha that is set as default in "setFieldsDict". However, I think only one of the alpha-files can have internalfield equal to "1" at the inlet.
As I said, I do not understand this fully myself, so please let me know if you find out something more!
multiphaseInterFoam vs multiphaseEulerFoam rahulksoni OpenFOAM 0 August 11, 2017 03:14
[snappyHexMesh] Normals abnormal? My snappyHexMesh mesh is crashing extrudeMesh :( KarenRei OpenFOAM Meshing & Mesh Conversion 9 October 5, 2016 23:50
How to keep the water level constant at inlet Tanjina FLUENT 10 January 21, 2016 11:29
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 11:22
