February 20, 2018, 03:19 |
Twophaseeulerfoam implementation
krishnan
Rep Power: 8 |
Hello !
I am planning to use twoPhaseEulerFoam for an internal turbulent multiphase flow. I have separate inlets for water and air and they will mix downstream. I plan to consider the air as a continuous phase and water as dispersed. My questions are: 1. Is twoPhaseEulerFoam suitable for these types of problems. Majority of the tutorials I see are based on using the solver for bubble flows. 2. Is there a model available within OpenFoam which can simulate this as a homogeneous mixture model (algebraic slip models)? For eg: can driftFluxFoam be used (I understood from the forum that this solver is more suitable for solid-liquid flows)? |
February 20, 2018, 23:08 |
Chen Sihe
Rep Power: 9 |
You may want to have a look at the breaking dam tutorial.. although that one uses interfoam instead.
twoPhaseEulerFoam: sudden crash | hcen | OpenFOAM Running, Solving & CFD | 18 | September 29, 2020 04:04 |
Implementation of rhoreactingFoam into twoPhaseEulerFoam | Polli | OpenFOAM Programming & Development | 1 | May 1, 2020 00:54 |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 18:45 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 09:10 |
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch | thomek | OpenFOAM Programming & Development | 0 | October 18, 2010 06:10 |
