High pressure gas atomization using compressibleInterFoam
Old   February 18, 2018, 12:36
Default High pressure gas atomization using compressibleInterFoam
Kalpana Hanthanan Arachchilage
kal1943335 is on a distinguished road
Dear all,
I'm trying to simulate high pressure gas atomization process using compressibleInterFoam. Pressure inlet boundary condition is used for gas inlet (Pressures 10-30atm) and fixed velocity boundary condition is used at the liquid inlet. Liquid is heated above 1000K and gas is entering at room temperature. I have tried many changes (in terms of boundary conditions, Pmin, momentum predictor and transonic conditions) but my simulation crashes after few time steps. One thing I have noticed is it creates liquid from the side outlet, which is not physical. And finally it crashes with negative temperature values.
I have attached an animation of my simulation and also my test case file herewith. I really appreciate if someone can help me with this.
Thank you again,
Kalpana
kal1943335 is offline   Reply With Quote
compressibleinterfoam, compressibleinterfoam bcs, divergence of temperature, high pressure injection, mass balance error
Can not use very high pressure with sonicFoam and rhoCentralFoam vasava OpenFOAM Running, Solving & CFD 4 October 22, 2024 14:05
How:Setting for High pressure gas shiwencailx STAR-CD 0 January 19, 2010 05:25
high pressure jet modeling Rufas FloEFD, FloWorks & FloTHERM 3 May 19, 2008 08:14
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
