simpleIbFoam with varaible density
Old   February 12, 2018, 15:17
Default simpleIbFoam with varaible density
Thamali
Thamali is on a distinguished road
I modified the code 'simpleIbFoam' for variable denisty and tried to run in an hpc.
It gives me the following error.('simpleIbFoam' runs without any issue).
Fatal error in MPI_Recv: Message truncated, error stack:
MPI_Recv(224).....................: MPI_Recv(buf=0x7ffdc2b6b720, count=24, MPI_PACKED, src=1, tag=1, MPI_COMM_WORLD, status=0x7ffdc2b6b6b0) failed
MPIDI_CH3U_Receive_data_found(131): Message from rank 1 and tag 1 truncated; 34368 bytes received but buffer size is 24
I tried
OptimisationSwitches
commsType nonBlocking;
and didn't work.
I went through Message truncated, error stack: MPIDI_CH3U_Receive_data_found
As instructed in there,I could not find a parallelTest.I'm using foam-extend/4.0
I appreciate if someone could help me.
Thanks,
Thamali
Thamali is offline   Reply With Quote
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
How to model Salinity, density, fresh water & sea water grayback87 FLUENT 3 December 30, 2014 03:00
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
