buoyantBoussinesqPimpleFoam: gravity term is not calculated?
Old   February 12, 2018, 04:40
Default buoyantBoussinesqPimpleFoam: gravity term is not calculated?
Fynn
PanPeter is on a distinguished road
I am investigating the buoyantBoussinesqPimpleFoam solver and believe the gravity term is not calculated:
The pressure and gravity terms in the Navier-Stokes equations are redefined as:
-\nabla \frac{p}{\rho_0} + \frac{\rho}{\rho_0}\mathbf{g}
= -\nabla p_{rgh} - \mathbf{gr} \nabla \frac{\rho}{\rho_0}
,where
p_{rgh} = \frac{p}{\rho_0} - \frac{\rho}{\rho_0}\mathbf{gr}
Now for the pimple loop:
1: Solving for the velocity field, where NSE with above pressure and gravity is solved.
2: The heat equation is solved, where \frac{\rho}{\rho_0} is updated.
3: Updating the pressure field in the nested pressure-correction loop, where p_{rgh} is updated.
Now for my problem:
I initialize the pressure field to be zero everywhere and disable the the pressure correction loop (nCorrectors=0 in fvSolution.PIMPLE). So the p_{rgh} field is zero and will always be zero. That kills the pressure gradient term in the NSE. The dynamics in the systems should then be induced though the gravity term \mathbf{gr} \nabla \frac{\rho}{\rho_0} alone but no motion develops! Does anybody have an idea why?
I attached a lock-exchange case example, in which the pressure loop is deactivated and the Prandtl number is set to 10^9 to disable heat diffusion.
PanPeter is offline   Reply With Quote
Old   February 15, 2018, 16:55
MSF
MSF is on a distinguished road
Nothing unexpected happens. Check buoyantBoussinesqPisoFoam: A detailed explanation
Best Moritz
MSF is offline   Reply With Quote
wallHeatFlux utility for an incompressible case Mr.Jingles OpenFOAM Post-Processing 67 April 6, 2023 04:25
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 04:09
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 02:52
coupled source term in 3 transport equations mhassani OpenFOAM Running, Solving & CFD 1 September 10, 2018 10:35
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 11:20
