Mathematical background for discretisation schemes |
February 7, 2018, 12:22 |
Ladferror
Hello everyone, at the moment I'm writing my masters thesis about simulating turbulent flows and we chose to do the simulations in OpenFOAM. Since I study mathematics, it would be important for me to also explain how discretization schemes are applied to the equations which are going to be solved numerically. For example I am using the pimpleFoam solver (for simulating the Kármán vortex street) and I would like to explain the "Gauss linear" scheme of gradSchemes in the fvSchemes file by applying it e.g. on the Reynolds-Averaged-Navier-Stokes-Equations by hand (in the file "turbulenceProperties" the simulationType is set to RAS). I looked it up in the UserGuide of OpenFOAM (where it is explained briefly but I wasn't able to understand it properly) and tried to find it online but I haven't found where this is explained. Therefore I wanted to ask, if there is some kind of documentation or some place where I could look it up, without looking through the program code. I wasn't sure where to post this or if there is a similar post, where this was already asked. Thank you for you answers. |
February 11, 2018, 12:05 |
#2 | |
Santiago Lopez Castano
Rep Power: 15 |
February 11, 2018, 16:01 |
#3 | |
mahdi
Rep Power: 10 |
1) An Introduction to Computational Fluid Dynamics by "H K Versteeg and W Malalasekera" 2) The Finite Volume Method in Computational Fluid Dynamics (An Advanced Introduction with OpenFOAM and Matlab) by " F. Moukalled L. Mangani M. Darwish" |
discretisation, mathematical analysis, schemes |
Fundamental questions about numerical schemes | Obad | OpenFOAM Running, Solving & CFD | 1 | May 10, 2021 10:40 |
Influence of schemes on mesh size, orientation and type in a convective flow field | Tobi | OpenFOAM Verification & Validation | 8 | July 16, 2017 08:01 |
correct finite volume schemes | babakflame | OpenFOAM Running, Solving & CFD | 2 | July 7, 2017 16:55 |
Suggest good book for FLUENT mathematical calculations background | Milo | FLUENT | 1 | April 20, 2012 21:04 |
time stepping schemes for compressible DNS/LES | shyamdsundar | Main CFD Forum | 0 | January 14, 2010 23:15 |
