use of porous media with sonicFoam or rhoCentralFoam |
February 2, 2018, 16:54 |
Rep Power: 9 |
Hello!
How can I use a porous media/cell zone with transient solver like sonicFoam or rhoCentralFoam? Do I need to implement the code for the porous zones in the solver or there is another way to do it? I want to use the porous zone near the walls and the sonicFoam/rhoCentralFoam for the far-field domain. Regards. |
February 8, 2018, 07:49 |
Deep
Rep Power: 9 |
Were you able to use those sovlers (esp. sonicFoam) for your case? Could you share the outcome please?
February 11, 2018, 02:02 |
#3 | |
mahdi
Rep Power: 11 |
If I understand correctly your question, you want to simulate a porous zone with a transient solver? right? you can define a porous zone in your mesh and then use fvOptions. If my answer is what you are looking for and you need further information please don't hesitate to ask. Bests |
February 13, 2018, 13:46 |
#4 | |
Rep Power: 9 |
Thank you for your answer. Yeah, that's what I need, more or less. I tried to define the porous zone with topoSetDict and then use the fvOptions as you said. It looks like it reads the porous zone when i run the solver but after 3 iterations i get this: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1706 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1706 Arch : "LSB;label=32;scalar=64" Exec : rhoCentralFoam Date : Feb 13 2018 Time : 19:16:39 Host : "themistoklis-desktop" PID : 14946 Case : /home/themistoklis/VKI/3D/LES/cases_folder/ss-LES-porosity1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Creating turbulence model Selecting turbulence model type LES Selecting LES turbulence model kEqn Selecting LES delta type vanDriest Selecting LES delta type cubeRootVol LES { LESModel kEqn; turbulence on; printCoeffs on; delta vanDriest; cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Ce 1.048; Ck 0.094; } Creating finite volume options from "system/fvOptions" Selecting finite volume options model type explicitPorositySource Source: porosity_wall - selecting cells using cellZone porosity_wall Porosity region porosity_wall: selecting model: DarcyForchheimer creating porous zone: porosity_wall coordinateSystem origin: (0 0 0) e1 (1 0 0); e2 (0 1 0); e3 (0 0 1); local bounds: (-2e+300 -2e+300 -2e+300) fluxScheme: Kurganov Starting time loop --> FOAM Warning : From function virtual void Foam::probes::findElements(const Foam::fvMesh&) in file probes/probes.C at line 122 Did not find location (0.5 0.5 0.35) in any cell. Skipping location. Mean and max Courant Numbers = 0.0011493 26.4788 deltaT = 1.8883e-10 Time = 1.8883e-10 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 5.90703e-08, Final residual = 2.44838e-17, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1.26004e-08, Final residual = 6.01289e-18, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 3.90837e-07, Final residual = 1.92179e-18, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 1.58267e-08, Final residual = 1.84018e-17, No Iterations 2 smoothSolver: Solving for k, Initial residual = 1, Final residual = 9.37399e-20, No Iterations 2 ExecutionTime = 6.42 s ClockTime = 7 s Mean and max Courant Numbers = 2.14605e-05 0.466437 deltaT = 2.02418e-10 Time = 3.91248e-10 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 2.22091e-08, Final residual = 1.2556e-18, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 4.60887e-09, Final residual = 4.60887e-09, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 2.09171e-07, Final residual = 6.71802e-18, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 5.00931e-09, Final residual = 5.00931e-09, No Iterations 0 --> FOAM Warning : From function virtual void Foam::fv::option::checkApplied() const in file cfdTools/general/fvOptions/fvOption.C at line 125 Source porosity_wall defined for field U but never used --> FOAM Warning : From function virtual void Foam::fv::option::checkApplied() const in file cfdTools/general/fvOptions/fvOption.C at line 125 Source porosity_wall defined for field U but never used This is my fvOption file: Code:
porosity_wall { type explicitPorositySource; active true; explicitPorositySourceCoeffs { type DarcyForchheimer; selectionMode cellZone; cellZone porosity_wall; // Specify the name of the cellZone DarcyForchheimerCoeffs { // Negative coeffs are multiplied by largest positive coeff, // taking the magnitude, e.g. for -1000, coeff = |1e7*-1000| = 1e10 d [0 -2 0 0 0 0 0] (1e7 -1000 -1000); f [0 -1 0 0 0 0 0] (0 0 0); coordinateSystem // Cartesian coordinates for the cellZone { x (1 0 0); y (0 1 0); #includeEtc "caseDicts/general/coordinateSystem/cartesianXY" } } } } Code:
actions ( { name porosity_wall;//center type cellZoneSet; action new;//add source boxToCell; sourceInfo { box (0.125 0 0)(0.12494365 0.75 0.1);//building_wall } } ); |
February 14, 2018, 00:50 |
#5 | |
mahdi
Rep Power: 11 |
Can you test your case with another solver like sonicFoam and let me know if it worked? I have no idea about rhoCentralFoam, but just check the source code and it seems it doesn't care about fvOptions in momentum equation: // --- Solve momentum solve(fvm::ddt(rhoU) + fvc::div(phiUp)); U.ref() = rhoU() /rho(); U.correctBoundaryConditions(); rhoU.boundaryFieldRef() == rho.boundaryField()*U.boundaryField(); if (!inviscid) { solve ( fvm::ddt(rho, U) - fvc::ddt(rho, U) - fvm::laplacian(muEff, U) - fvc::div(tauMC) ); rhoU = rho*U; } And this could be the reason for this warning: Source porosity_wall defined for field U but never used However, for the other solvers like sonicFoam momentum equation solve like this: // Solve the Momentum equation MRF.correctBoundaryVelocity(U); fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(phi, U) + MRF.DDt(rho, U) + turbulence->divDevRhoReff(U) == fvOptions(rho, U) ); UEqn.relax(); fvOptions.constrain(UEqn); if (pimple.momentumPredictor()) { solve(UEqn == -fvc::grad(p)); fvOptions.correct(U); K = 0.5*magSqr(U); } And as you can see, there is fvOptions in RHS of the equation as the source term. Regards, |
September 15, 2018, 21:34 |
#6 | |
Rep Power: 9 |
You were right, rhocentralfoam couldn't 'read' the porous medium on the wall. In order to do so, I modified the momentum equation of rhocentralfoam and it works. Sorry for the late reply. |
May 7, 2020, 12:12 |
#7 | |
Rep Power: 8 |
Dear Calmly, could you post your solution for rhoCentralFoam? I am very interested how you changed the code to make it work. Regards, shock77 |
media, porous, rhocentralfoam |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 8 | May 30, 2024 03:59 |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 03:55 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 11:34 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
