Pressure driven flow Boundary Conditions needed
Old   February 2, 2018, 15:47
Default Pressure driven flow Boundary Conditions needed
Juergen Kodelka
JuergenKodelka is on a distinguished road
Good evening,
I am trying to solve a conjugate heat transfer problem through a simple electronics device case. The case geometry is a simple box with 4 rounded shaped holes. 2 fans are blowing air into the case where as the other 2 holes on the other side of the case function as outlets. How do I setup the boundary conditions for this setup? I do know the mass flow rate and pressure the fans are operating at. The gas is air.
Is there a possibility to apply both pressure and mass flow rate at the inlet?
For the outlet I think I dont need any BC then
Thank you very much for your time.
JuergenKodelka is offline   Reply With Quote
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 13:16
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
