wallHeatFlux buoyantBoussinesqPimpleFoam
Old   January 31, 2018, 17:11
Default wallHeatFlux buoyantBoussinesqPimpleFoam
Gary
gkuepper is on a distinguished road
Hi All,
I'm using buoyantBoussinesqPimpleFoam to solve convective heat transfer between concentric cylinders. I need to calculate the heat flux going from the inner to outer cylinders.
I've tried using wallHeatFlux to do this. First time I tried it it required a thermophysicalProperties file. Which I included.
Now I'm getting this message
--> FOAM FATAL ERROR:
LHS and RHS of + have different dimensions
     dimensions : [1 -1 -1 0 0 0 0] + [0 2 -1 0 0 0 0]
I get my dimensions are off with some value, but which one??
my wallheatfluxdict
|  \\    /   O peration     | Version:  1.0                                   |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
FoamFile
    version         2.0;
    format          ascii;
    root        ".";
    case         "test";
    instance        "system";
    local           "";
    class           dictionary;
    object          sampleDict;
// List of boundaries and face sets
bcs
    MountFace
    CylinderID
    Gearbox
    Motor
    CylinderEndFace
I'm using blueCFD 2016 on Windows 7 FYI. I'm kind of stuck with what I got for now.
gkuepper is offline   Reply With Quote
Time-average of a patch (wallHeatFlux) milabvieira OpenFOAM Post-Processing 16 February 28, 2019 02:03
wallHeatFlux utility with sonicFoam hiuluom OpenFOAM Post-Processing 3 September 18, 2015 08:39
how to use wallHeatFlux for incompressible problem? hswzzz OpenFOAM Post-Processing 1 April 14, 2015 07:25
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 17:47
problem with WallHeatFlux Roman1 OpenFOAM Running, Solving & CFD 1 January 24, 2014 11:31
