Proper boundary & initial value for a water turbine
Old   January 31, 2018, 02:05
Default Proper boundary & initial value for a water turbine
Shin Soyong
Yohan is on a distinguished road
Hello everyone,
I am an undergraduate student, not familiar to OpenFOAM and global CFD field.
So I really need a help from you guys..
These days I am trying to analyze a water turbine inside the pipe.
Size of the turbine is about 0.4m, and inflow velocity is 6m/s.
Furthermore, turbine is rotating at 380RPM.
What I want to know is that, how can I set initial value of k and epsilon value and which boundary condition is necessary to the wall (pipe wall and turbine)?
I am using boundary conditions for k as
kqRWallFunction with $internalField
and epsilon as
epsilonWallFunction with $internalField.
Furthermore, for the initial value, I use turbulence calculator in this website and set turbulence intensity as 1%, Eddy viscosity ratio as 0.1
What I found was, the value of turbulence intensity is vary according to the situation, but I don't know which value is proper for this case.
If anyone has an idea about this case, please help me.!
Thanks in advance.
Yohan is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
