January 30, 2018, 15:54 |
Run with option -parallel, but in serial
Thomas Oliveira
Rep Power: 12 |
Hi everyone,
Is it possible (and if it isn't, would it make sense) to run utilities with the option -parallel, but in serial or in a different number of processors? Let me illustrate with the example of a use case. I am preparing a model to be run in 432 processes on a cluster (on 432 cores). The cluster has a queue of some hours. I wanted to run renumberMesh -parallel before running the model. Ideally, I would be able to do it on my desktop, either in serial or using its 12 cores. The operation wouldn't take too long and I would avoid the queue. Is it conceptually possible to implement that? Is it implemented already? Thank you for your help, Thomas Oliveira |
parallel, renumbermesh, utilities |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
