Model two phase system of water and solid particle using twoPhaseEulerFoam
Old   January 26, 2018, 10:49
Default Model two phase system of water and solid particle using twoPhaseEulerFoam
Kai Jiang
Jack_Kerouac is on a distinguished road
Hello, Foamer
I want to discuss a problem about two phase system of water and solid particle( slurry flow in 3D pipeline ) using twoPhaseEulerFoam.
The basic description about the problem i'm studying:
1.the solid-liquid two phase flow, that is slurry flow(belongs to ).
2.This is an isothermal flow. So, It doesn't have to solve the temperature equation from the document-"twoPhaseEulerFoam.C".
3.It is considered that the drag force and turbulent diffusion force affect the interphase momentum exchange.
4.the volume fraction of solid particle is more than or equal to 0.2.
5.the initial inlet velocity of water is 0.25m/s. the initial lnlet velocity of solid particle is 0m/s.
The problem i met :
The calculation has always been divergent and the terminal display the denominator is 0 during the process of calculation.
In order to solve the problem, I have checked the quality of mesh, it's ok.
So, i'm not sure Whether the Boundary conditions and initial conditions is right.
Last edited by Jack_Kerouac; January 28, 2018 at 03:11. Reason: add initial conditions
Jack_Kerouac is offline   Reply With Quote
Old   January 26, 2018, 11:44
Kai Jiang
The file of checkMesh indicates the Mesh is ok.
Last edited by Jack_Kerouac; January 28, 2018 at 03:27. Reason: add the file of checkMesh
Old   January 27, 2018, 06:00
Kai Jiang
During the calculation, the courant Number can be up to 0.8. What's more, the No Iterations of P_rgh is always 1000, leading to waste more time to model two phase system.
Last edited by Jack_Kerouac; January 28, 2018 at 03:34. Reason: add the problem i met
Old   January 27, 2018, 06:05
Kai Jiang
The important initial conditions and BC have been uploaded in the following reply.
Last edited by Jack_Kerouac; January 28, 2018 at 03:40. Reason: add problem description
Old   January 27, 2018, 20:26
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Hello, why not posting the actual text content of your files instead of impossible-to-be-edited images?
Post the content the files you believe are important to be read inside a [CODE] tag, together with your case tar-gzipped (without the mesh, just the configuration files) as attachment.
Please remove the images
rdbisme is offline   Reply With Quote
Old   January 27, 2018, 21:57
Kai Jiang
I'm sorry to make you confused. OK, i will upload the actual file.
Old   January 28, 2018, 03:02
Kai Jiang
Hello, i have uploaded the actual file(ZIP) in TXT format.
Old   January 28, 2018, 03:43
Kai Jiang
The file of checkMesh has been upload in the above reply.
slurry flow, solid-liquid two phase, twophaseeuelrfoam
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
