supersonic flow with openfoam
Old   January 25, 2018, 12:49
Default supersonic flow with openfoam
power
enginpower is on a distinguished road
Hello guy,
I'm stuck with a supersonic flow case using Openfoam on SimScale here.
It is a very complicated case with a high pressure drop, supersonic flow in the nozzles, multiple nozzles, etc...
You can see there all the settings and ask me what you want to get the solution.
Thanks to who wants to help
enginpower is offline   Reply With Quote
Old   January 26, 2018, 08:20
Chris Fisichella
fisichel is on a distinguished road
I would try running some cases and look at the feedback OpenFoam gives to you. Many of the error messages are solved by doing a web search. OpenFoam has compressible flow tutorial cases. I would highly recommend starting from one of those tutorial cases and make small changes in the direction you want the calculation to proceed.
Best Regards,
Chris
Originally Posted by enginpower View Post
Hello guy,
fisichel is offline   Reply With Quote
supersonic
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
Can not achieve statistically steady flow in Openfoam jiaodanuma OpenFOAM 0 August 16, 2016 07:49
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 16:13
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
