Fluctuation Scale in LES
Old   January 25, 2018, 12:41
Default Fluctuation Scale in LES
Friendly is on a distinguished road
I would like to know what exactly is meant by fluctuation scale in OpenFOAM. My goal is to create a turbulent inlet with fluctuation velocity.
For this I need to define a fluctuation sclale, but I dont know whicht value would be appropriate, because I dont know which is meant by that.
This is from turbulentInletFvPatchField.H:
Class
     Foam::turbulentInletFvPatchField
 Group
     grpInletBoundaryConditions
 Description
     This boundary condition generates a fluctuating inlet condition by adding
     a random component to a reference (mean) field.
     \f[
         x_p = (1 - \alpha) x_p^{n-1} + \alpha (x_{ref} + s C_{RMS} x_{ref})
     \f]
     where
     \vartable
         x_p     | patch values
         x_{ref} | reference patch values
         n       | time level
         \alpha  | fraction of new random component added to previous time value
         C_{RMS} | RMS coefficient
         s       | fluctuation scale
     \endvartable
 Usage
     \table
         Property     | Description             | Required    | Default value
         fluctuationScale | RMS fluctuation scale (fraction of mean) | yes |
         referenceField | reference (mean) field | yes        |
         alpha | fraction of new random component added to previous| no| 0.1
     \endtable
     Example of the boundary condition specification:
     \verbatim
     <patchName>
         type            turbulentInlet;
         fluctuationScale 0.1;
         referenceField  uniform 10;
         alpha           0.1;
     \endverbatim
Friendly is offline   Reply With Quote
Old   January 26, 2018, 08:24
Chris Fisichella
fisichel is on a distinguished road
You did the right thing by pulling up the header file. In that equation they typed, they are multiplying the RMS coefficient by the scaling value. I think 1 would be a good start. I see they example later on they set the scaling value to 0.1. I don't have an answer for that except to say they are using that parameter to scale their turbulence in a convenient manner.
Best Regards,
Chris
Originally Posted by Friendly View Post
Class
 Group
 Description
     \f[
     \f]
     where
     \vartable
         x_p     | patch values
         n       | time level
     \endvartable
 Usage
     \table
     \endtable
     \verbatim
     <patchName>
         alpha           0.1;
     \endverbatim
fisichel is offline   Reply With Quote
Old   January 26, 2018, 17:59
thanks for your reply.
1 seems big for fluctuations, but I may be wrong, it depends on what is meant by that. I have the assumption that s (fluctuation scale) is u', u'u' or sqrt(1/3ux'ux'+uy'uy'+uz'uz'). But I couldnt find any hints in the web.
Does nobody use the turbulentInlet boundary condition?
Old   November 4, 2020, 22:02
ESI
ht2017 is on a distinguished road
Did You have resolved this problem? Now I am facing a similar your problem. Please give me some advice if you have a solution.
ht2017 is offline   Reply With Quote
Old   November 5, 2020, 01:18
Ruiyan Chen
cryabroad is on a distinguished road
It's a percentage, the actual fluctuating value is whatever you have for the scale times the mean value.
From my experience 0.05, or 5% is a good value to start.
cryabroad is offline   Reply With Quote
Old   November 5, 2020, 04:23
ESI
could you explain detail that? I still do not understand your advice. sorry for my rookie question.
Turbulent inlet fluctuation scale christian OpenFOAM Running, Solving & CFD 2 November 3, 2023 08:14
Calculating resolved scale k and epsilon (LES) pm11dt OpenFOAM Post-Processing 0 March 28, 2017 10:59
3D velocity fluctuation profiles from a file in initialization section using LES. Aramisss CFX 0 July 8, 2015 17:24
LES inlet length scale f.neilson Main CFD Forum 0 January 31, 2005 14:26
Length scale separation in LES Ray Main CFD Forum 1 June 7, 2002 09:50
