January 23, 2018, 05:50 |
Wall Function for nuTilda
Rep Power: 12 |
Dear FOAMers,
I am currently testing different turbulence models for a simulation with a mesh, which has no consistent boundary layer (y+ varying from 5 to 60 over the whole geometry), therefore I am using wallfunctions, which are suitable both for low re and high re areas. As an one-equation model, spalart-allmaras model gives me very good results. But my question is: Is it correct to use nutUSpaldingWallFunction as a boundary condition for my walls in the nuTilda file? Or do I have to set fixedValue = 0 like in the airfoil2D tutorial? I found both ways in different publications, so I am a Little bit confused and hope you can help me. Best regards |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 12:55 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 03:30 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
