buoyantSimpleFoam for Solar Chimney - Max number iteration exceeded.
Old   January 22, 2018, 17:22
Default buoyantSimpleFoam for Solar Chimney - Max number iteration exceeded.
Olivier Dambron
olivierdambron is on a distinguished road
Hi guys I'm running buoyantSimpleFoam for a solar chimney. I am basing my case on the tutorial 'hotRadiationRoom' to which I add an inlet and an outlet.
I am getting the following error, any chance you guys know how I can move forward? I attach hereby my /0 folder with my BC.
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p_rgh tolerance 0.01
field U tolerance 0.001
field h tolerance 0.001
field G tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Reading g
Reading hRef
Calculating field g.h
Reading field p_rgh
No MRF models present
Selecting radiationModel P1
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
Selecting sootModel none
No finite volume options present
Starting time loop
Time = 1
Time = 4
Duration of pickling 0.0978538990021 too long. Extending frequency from 1.0 to 4.8926949501
DILUPBiCGStab: Solving for Ux, Initial residual = 0.2111138, Final residual = 7.33545e-05, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.4600708, Final residual = 0.0002523532, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 0.352951, Final residual = 0.0001029493, No Iterations 1
DILUPBiCGStab: Solving for h, Initial residual = 0.0007439446, Final residual = 2.572517e-07, No Iterations 1
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Maximum number of iterations exceeded: 100
[1]
[1] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam:erfectGas<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleEnthalpy>]
[1] in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 73.
[1]
FOAM parallel run aborting
olivierdambron is offline   Reply With Quote
Old   January 23, 2018, 12:59
clapointe is on a distinguished road
It looks like the velocity and pressure boundary conditions have not been changed from the tutorial case -- it was created to simulate heat transfer inside a closed room. If you want to allow flow in/out of the domain, you will need to change them.
Caelan
clapointe is offline   Reply With Quote
Old   January 23, 2018, 13:06
Olivier Dambron
HI Caelan,
Thanks for the reply. I would like just to input temperature and monitor velocity and pressure.
What kind of BC for U, p and prgh would you recommend?
For U:
outlet
type pressureInletOutletVelocity;
value uniform (0 0 0);
inlet
For p:
outlet
type calculated;
value uniform 100000;
inlet
type calculated;
For p_rgh:
outlet
type fixedValue;
inlet
type fixedFluxPressure;
Old   January 23, 2018, 13:20
Those are starting to look more like what you'd want. They might work -- you might also try total pressure (for pressure) and inlet outlet (for velocity) and see if the results look physical.
Caelan
Old   January 23, 2018, 13:27
Olivier Dambron
I also have to change my fvschemes. I'm a bit in the dark, is this ok? without it the temperature dives big negative and crashes.
This is what I'm using at the moment
ddtSchemes
default steadyState;
gradSchemes
default cellLimited leastSquares 1;
divSchemes
default none;
div(phi,T) bounded Gauss linearUpwind default;
div(phi,U) bounded Gauss upwind;
div(phi,K) bounded Gauss upwind;
div(phi,h) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited corrected 0.333;
interpolationSchemes
default linear;
snGradSchemes
default limited corrected 0.333;
For comparison this is the one of the tutorial:
ddtSchemes
gradSchemes
default Gauss linear;
divSchemes
default none;
laplacianSchemes
default Gauss linear corrected;
default linear;
snGradSchemes
default corrected;
Old   January 23, 2018, 13:30
The schemes from the tutorial are a good place to start. They're mostly first order so you can change them to be less diffusive once you have the case running.
Caelan
Old   January 23, 2018, 13:51
Olivier Dambron
Caelan, many thanks for the help.
When I use the tutorial's scheme , my temperature dives to extremes and goes negative. I'm really unsure of how to make it less diffusive, any chance you could let me know? or point me to some relevant reading?
sorry for being a bit assisted here.
Old   January 23, 2018, 13:58
It's most likely an issue with your case setup if the temperature immediately goes negative -- try changing your boundary conditions. This is a good place to start reading about setting up fvSchemes : https://www.openfoam.com/documentati.../fvSchemes.php.
Caelan
Old   January 23, 2018, 14:04
Olivier Dambron
Thanks Mate.
Olivier
Old   January 23, 2018, 16:24
Olivier Dambron
OK I've read the page and if I understand correctly, I made it less diffusive by changing :
laplacianSchemes
{default Gauss linear corrected;}
to
laplacianSchemes
{default Gauss linear limited 0.5;}
Its running well now.
thanks for pushiing me to find the answer!
Old   January 24, 2018, 15:42
Olivier Dambron
Dear Caelan,
although I have reduced the laplacian schemes to make it less diffusive, the simulation runs and diverges at time 90 for the same reason 'nb of iteration exceeded'.
Should I reduce even more?
laplacianSchemes
Old   January 24, 2018, 22:19
There are many potential ways to make the simulation less diffusive. However, it is hard to tell why your case is failing without seeing the whole thing -- can you include it?
Old   January 25, 2018, 10:19
Olivier Dambron
Here attached is the last version that runs until time 90.
after surfacefeatureextract,blockmesh,snappy,buoyantSimp leFoam.
If you could take a look it would really be of great help.
Olivier
Old   January 25, 2018, 13:07
How are you running your case? There are only walls created by your blockMeshDict at the moment -- without further modification you will not have an inlet or outlet.
Caelan
Old   January 25, 2018, 13:20
Olivier Dambron
My case is a bit crafty using Butterfly on Grasshopper for Rhino. I write the case and then modify all using notepad.
Those walls you are seeing are the boundary volume, the following should make it run:
surfacefeatureextract,blockmesh,snappyhexmesh,buoy antSimpleFoam.
you may need to copy constant folders into the times. If you wish I could send you the meshed case more or less 170 mb. I could send you a wetransfer if needed.
Old   January 25, 2018, 13:52
The case ran for me at significantly lower resolution, but I do not know enough about your problem to interpret the results. I expect you still have a problem with the case setup -- try looking at boundary conditions used for the buoyantSimpleFoam tutorials.
Caelan
Old   January 25, 2018, 14:03
Olivier Dambron
thanks for looking into it.
What Im trying to analyze is the volumetric flowrate induced by the buoyancy in the solar chimney. So Im inputing only temperatures which are taken form an thermodynamic model. pressures and velocity are what im looking for.
The BC used for buoyantSimpleFoam in the tutorial do not show for inlets and outlets.
Old   January 25, 2018, 14:05
I should have been clearer -- other buoyantSimpleFoam tutorials have inflow/outflow. Like this one : https://github.com/OpenFOAM/OpenFOAM...itBoardCooling
Old   January 28, 2018, 13:50
Olivier Dambron
Dear Clapointe,
I've tried over and over again and I have to admit that Im a bit lost. Would you be keen on helping me set this case so I can refer to it for further iterations and learn from a steady base?
Kind regards,
Olivier
Old   January 29, 2018, 18:37
I do not have time to work too much on your case, but I'd recommend that you keep working on the case setup -- boundary conditions leading to unphysical behavior are often the cause for crashes.
Caelan
buoyantsimplefoam, solar chimney
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
