problems with slcsVOFFoam
Old   January 22, 2018, 11:52
Default problems with slcsVOFFoam
cyw
Yuanwei Cao
cyw is on a distinguished road
Dear Foamers,
I am studing the implementation of level set into interFoam. And I dound several problems with this solver.
1. When I run this solver in parallel, the result is not the same as the serial result.
2. It can not control parasitic current very well. For a static bubble in still water without gravity, the parasitic currents still exist.
Has some body met these above problems?Can anyone help?
Best Regards
CYW
cyw is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
