January 20, 2018, 06:42 |
problem in solving
Chayanit Nigaltia
Rep Power: 8 |
I have imported mesh file from ANSYS and it worked properly but when I ran the solver it is showing the following error.
FOAM FATAL IO ERROR: cannot find file file: /home/dell/OpenFOAM/OpenFOAM-3.0.0/tutorials/incompressible/pimpleDyMFoam/wingMotion/new_wing/0/pointDisplacement at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
January 22, 2018, 06:46 |
#2 | |
Ricky
Rep Power: 12 |
Hallo CHAYANIT,
I haven't worked with dynamic meshes so far. But as per your error it says that you don't have pointDisplacement initialized in your 0 folder. Have a look at incompressible/pimpleDyMFoam/wingMotion tutorials. Perhaps most of your questions will be answered. Hope this helps! Regards, Ricky Quote:
If it is easy, then something is fishy! |
February 9, 2018, 05:55 |
Chayanit Nigaltia
Rep Power: 8 |
I am new on OpenFOAM. So to use OpenFoam is it necessary to know C++??
February 9, 2018, 14:25 |
Chayanit Nigaltia
Rep Power: 8 |
Thank you.
I worked with wing motion tutorial that you suggested.Bur on solving, it is showing the following error. Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: sixDoFRigidBodyMotion --> FOAM FATAL IO ERROR: cannot find file file: /home/dell/OpenFOAM/OpenFOAM-3.0.0/tutorials/incompressible/pimpleDyMFoam/wingMotion/no/0/pointDisplacement at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
