January 19, 2018, 08:43 |
Need Help: Foam::error::printStack
Zhong Ren
Hi, I am pretty new to OpenFoam. I am using sprayFoam to simulate high pressure diesel ignition and after about 0.001s, the following error comes. I don't understand the error code. Does anyone have any idea? Thanks
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? in "/lib/x86_64-linux-gnu/libm.so.6" #4 exp in "/lib/x86_64-linux-gnu/libm.so.6" #5 Foam::IrreversibleReaction<Foam::Reaction, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >, Foam::ArrheniusReactionRate>::kf(double, double, Foam::Field<double> const&) const at ??:? #6 Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::omega(Foam::Reaction<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > const&, Foam::Field<double> const&, double, double, double&, double&, int&, double&, double&, int&) const at ??:? #7 Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::omega(Foam::Field<double> const&, double, double, Foam::Field<double>&) const at ??:? #8 Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::derivatives(double, Foam::Field<double> const&, Foam::Field<double>&) const at ??:? #9 Foam::seulex::seul(double, Foam::Field<double> const&, double, int, Foam::Field<double>&, Foam::Field<double> const&) const at ??:? #10 Foam::seulex::solve(double&, Foam::Field<double>&, Foam::ODESolver::stepState&) const at ??:? #11 Foam::ODESolver::solve(double, double, Foam::Field<double>&, double&) const at ??:? #12 Foam::ode<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::solve(Foam::Field<double>&, double&, double&, double&, double&) const at ??:? #13 double Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve<Foam::UniformField<double> >(Foam::UniformField<double> const&) at ??:? #14 Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve(double) at ??:? #15 Foam::combustionModels::laminar<Foam::combustionModels::psiChemistryCombustion>::correct() at ??:? #16 Foam::combustionModels::PaSR<Foam::combustionModels::psiChemistryCombustion>::correct() at ??:? #17 ? at ??:? #18 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #19 ? at ??:? ./test: line 3: 3348 Floating point exception(core dumped) sprayFoam > log |
October 17, 2024, 11:56 |
#2 | |
Jehan Sharook Rassdeen
Rep Power: 2 |
Foam::error::PrintStack in GAMGSolver | davidicl | OpenFOAM Running, Solving & CFD | 1 | October 22, 2015 08:57 |
Foam::error::printStack in interDyMFoam when changing the floatingObject case | chun | OpenFOAM Running, Solving & CFD | 2 | August 7, 2014 03:53 |
New solver problems (Foam::error::printStack) | Elix1D | OpenFOAM Running, Solving & CFD | 9 | July 17, 2014 16:18 |
Foam::error::printStack | 1988 | OpenFOAM Running, Solving & CFD | 2 | April 18, 2014 06:36 |
#0 Foam::error::printStack (MotorBike tutorial) | GPan1 | OpenFOAM Running, Solving & CFD | 0 | November 4, 2012 05:48 |
