Stratified liquid in a rotating cylinder
Old   January 17, 2018, 03:04
Post Stratified liquid in a rotating cylinder
Shin Soyong
Yohan is on a distinguished road
Hello everyone.
I am Yohan, undergraduate student and new to OpenFOAM and CFD.
Recently I am planning to analyze fluid in the rotating cylinder and I encounter some difficulties to ask.
1. My object is to simulate two miscible (initially stratified) two liquids in the rotating cylinder, but I am not sure about which solver would be suit for the case.
I need to use Dynamic mesh, so that I am looking for interDyMFoam or multiphaseInterDyMFoam. Do these solvers include analysis about miscible liquids? Or should I use twoLiquidMixingFoam and modify code to use dynamic mesh?
2. For making a prism layer, I calculated the y+ value based on my knowledge but it comes to quite large value.
I set free stream velocity as radii x angular velocity,
density and dynamic viscosity as lower fluid properties,
boundary layer length as 2pi times radii
and Y+ value as 30.
is it right? or do I have to convert some values on it?
Thanks in advance and have a nice day everyone.!
Yohan is offline   Reply With Quote
Old   January 17, 2018, 03:56
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I don't know if I understand you right. But it may be easiest simulation a fixed volume and a cylinder with moving walls. A very simple example of this you may find in the lid driven cavity example where one of the wall is moving.
I think the interfoam solver would be appropriate for you.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   January 23, 2018, 05:05
Shin Soyong
Dear Uwe Pilz,
Thank you for your reply!
Before starting the simulation, I am trying to understand VOF method and mathematical analysis.
It seems to be hard for me now, however I am going to understand according to your advice!
Thank you again!
- Yohan
Calculation diverges, Liquid behavior around a rotating object toru OpenFOAM Running, Solving & CFD 0 December 1, 2016 11:54
Lift Cylinder in Liquid using ANSYS MikeShuo Main CFD Forum 0 October 24, 2016 02:46
Flow past rotating cylinder: Problem with ForeCoeffs raf1111 OpenFOAM 1 December 16, 2013 10:45
Spinning cylinder in viscous liquid - a serious doubt doctsh FLOW-3D 18 February 19, 2010 09:41
Rotating cylinder with liquid propbala03 FLOW-3D 1 October 1, 2009 00:52
