renumberMesh utility prevents AMR for snappy meshes
Old   January 16, 2018, 12:33
Default renumberMesh utility prevents AMR for snappy meshes
Peter
potentialFoam is on a distinguished road
Dear Foamers,
using the adaptive mesh refinement (AMR) tutorial for Foam version v1706 under
OpenFOAM-v1706/tutorials/multiphase/interDyMFoam/RAS/motorBike
shows that it works for meshes which are not purely hexahedral - wow!
A problem will occur if
renumberMesh
is executed after the meshing procedure with snappyHexMesh: the cells which are not purely hexahedral will become protected from refinement.
Before that (default tutorial settings), interDyMFoam announces:
Detected 535 cells that are protected from refinement.
After renumberMesh, it tells us the following:
Detected 3647 cells that are protected from refinement.
This error is pretty annoying because renumberMesh is a valuable utility and AMR also - but their combination doesn't work.
Question: Do you have a workaround? Or was it fixed for v1712?
(At least there are no issues containing 'renumberMesh' on https://develop.openfoam.com/Development/OpenFOAM-plus/issues )
potentialFoam is offline   Reply With Quote
[mesh manipulation] Some questions on blockMesh, decomposePar and renumberMesh Leech OpenFOAM Meshing & Mesh Conversion 19 April 5, 2019 20:21
[mesh manipulation] decomposePar Method affects executability of renumberMesh Vyssion OpenFOAM Meshing & Mesh Conversion 0 November 3, 2016 08:57
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 17:47
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 27, 2008 00:58
