different result between seriel and parallel running
Old   January 15, 2018, 05:05
Default different result between seriel and parallel running
cyw
Yuanwei Cao
cyw is on a distinguished road
Dear Foamers,
I implemented level set method into interFoam. I found an interesting problem. For serial and parallel running, the result is different. Anyone meets this problem? Anyone knows why?
cyw is offline   Reply With Quote
Old   August 22, 2018, 17:33
Arthur
Artur.Ant is on a distinguished road
I also found this problem in my simulations. By the way in some cases I observed that turbulent kinetic equation (in rhoSimpleFoam) after the first iterations has residuals of order of e-09 and this is impossible. Solving the same problem in serial way gave good, realistic and pretty stable (steady state) results.
Have you solved this difference in results between serial and parallel solver?
Artur.Ant is offline   Reply With Quote
interfoam, level set, parallel, serial
overlapGgi parallel 1.6-ext linnemann OpenFOAM Running, Solving & CFD 7 January 24, 2011 12:03
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 04:35
