Different OF versions <--> Different results? |
January 13, 2018, 07:16 |
Luca
Rep Power: 9 |
Dear Foamers,
I am currently working, for my master thesis dissertation, on a RANS simulation of a high speed train. In particular the focus of my analysis is on the pantograph, which is the component on the roof of the train whose main task is to collect current from the high voltage line. Since I was extending the validity of a model proposed in the past by a colleague, I did the simulations with the same version of OF used by him ( OpenFOAM v2.3.0 ). Everything went good and I did get a good correspondence with the experimental results. Unfortunately, the HPC ( high performance computing ) service which I used, decided to update the openFoam version to the latest one v1706. Since I have still to perform some simulations, which will be compared to the first one, I decided to re run the first simulation on the new version of openFoam. With my great surprise, even by using the same exact scripts used in the previous version, all my aerodynamic forces are a bit different now and there is no correspondence with the experimental results anymore. So the question now is: is it possible that changing only the OF version we get different results? I am sorry if the question is not clear or you need more information to understand. In this case let me know and I will more than happy to provide further information. I trust in your patience and kindness, there the risk I loose a valuable work for which I spent a lot of months with the hard to face consequence of further postponing my graduation. Thanks a lot for your attention, Luca |
January 13, 2018, 10:12 |
Answering your explicit question: yes, it is possible. Case can even converge [when run] with one version and diverge with another. Guess, implicit part includes: "what shall I do to get the same results with another version?". For this it is necessary to learn more about your case: solver, schemes, convergence criteria, mesh quality. |
January 13, 2018, 12:50 |
Luca
Rep Power: 9 |
Hi alexeym ,
thanks for your reply. It may seem a stupid question, but how can the solution change when we use the same algorithm and convergence criteria? I've always used simpleFoam, but the two version converge to two different values... and we are not talking about small differences which could be due do a different initialization of the solution... I have also obtained a force of 20N instead of 30N obtained with the older openFoam version... I ask you this question, because it's gonna be hard now to replicate the same result, as I've already done a convergence analysis and the solution seems to be not affected by an additional refinement of the mesh... Thanks, Luca |
January 13, 2018, 13:33 |
Taher Chegini
Rep Power: 12 |
As Alexeym said it's possible and for this reason I always compile OF on clusters myself and maintain it exactly the way I do on my own machine so I can always get the results that I want. Compilation shouldn't take more than 2 or 3 hours on a cluster.
January 13, 2018, 16:51 |
Hi all,
@streamline90 So, it seems you are in the mood to talk. OK. Well, what if, algorithm slightly changed between 2.3.x and 5.x? Also at this point it becomes even more interesting, since we compare Foundation's 2.3.x and ESI's 1706. So in addition to 2.3.x -> 5.x evolution you have additions by ESI team (yet it seems particularly simpleFoam is not changed). In addition, it is TVA, so velocities are relatively high, flow is turbulent. Turbulence library is COMPLETELY rewritten between 2.3.x and 5.x. And models with the same name can give different results depending on version. Your mesh is completely orthogonal? What if non-orthogonal correction was changed in between versions? And more generally, what if implementation of certain schemes was changed between versions? Just recently I had small issue: laminar pimpleFoam case converged fine on Foundation's 5.x and did not on ESI's 1706. And it turned out, that ESI's 1706 has issues with Crank-Nicolson scheme implementation, which lead to convergence problems. Though at a surface: the same algorithm, the same orthogonal mesh, the same scheme names. Mesh convergence analysis is fine, when you know, that your schemes are really 1st or 2nd order. What if your schemes are 0-order (like Gauss linear on non-orthogonal meshes) and just give you wrong results on any mesh? |
January 14, 2018, 11:31 |
#6 | |
Santiago Lopez Castano
Rep Power: 15 |
One that i remember was regarding the implementation of the dynamic smagorinsky model in OF2.1, made by Weller, which was implemented wrong. My .02 cents are to stick with things that you have proven they work. I just recently migrated to foam-extend after working with v.2.1. Migrate only when deemed necessary. |
January 15, 2018, 06:47 |
case files attached
Luca
Rep Power: 9 |
Hello guys,
thanks for sharing your thoughts on the subject, I really appreciate. @alexeym Your answer is really detailed and I am gonna check the schemes, hoping this is not taking me too much time. It took me a lot to create a validated case, and since the graduation is in April and I still need to write down my dissertation I have to think about the best solution. Maybe, as suggested by @Santiago, the best solution would be to stick with the case which has proven to be valid. The problem, in this case, would be that I couldn't proceed with my research, as further results cannot be compared. If anyone has time to go through them, I attach below the setup files for the latest case submitted in OFv1706. I am working on my own with OF since a year and as a mechanical engineer, I don't have such a wide background in fluid mechanics and CFD: feel free to warn me about even the stupidest of the errors and please be patient if I have done childish mistakes. (there are also the log files of the meshing and solving process) https://drive.google.com/open?id=1JY...btdGVl2MHf9miv Thanks a lot and have a great day! Luca |
January 15, 2018, 15:48 |
@streamline90
Let me clarify one thing first: did you analyse your flow field or you have just compared output of forces/forceCoeffs function objects? What if in fact just description format of these function objects was changed? Now to your files: - Do you plan to view your files in text viewer? Otherwise it is not quite clear why would you like to write files in ASCII format. Also why precision is 7? Why not 12? Or 15? In fact your non-orthogonality can be caused by write precision. - "Gauss linear" is OK only for orthogonal meshes. On non-orthogonal meshes (especially your 70 degrees of non-orthogonality) it has certain problems (you can search forum for references, also there is NASA paper: https://ntrs.nasa.gov/archive/nasa/c...0140011550.pdf). |
January 15, 2018, 16:12 |
#9 | |||
Luca
Rep Power: 9 |
January 16, 2018, 07:33 |
#10 | |||
May 15, 2018, 12:15 |
Differences in results
#12 |
Adithya Gurumurthy
Rep Power: 9 |
Hello Luca! I am having the exact issue. I validated my particle simulations with OpenFOAM 3.0.1, but the HPC system has v1706 and the deposition results are way off. Did changing the schemes fix it for you?
May 17, 2018, 09:19 |
#13 |
Luca
Rep Power: 9 |
Hello Adithya! In the end I didn't try to change the schemes since my HPC allows to recover previous versions of openFoam so I have been using OF v2.3.0 again.
I am sorry I can't help you, in case you see significant changes please let us know! Have a great day, Luca |
comparison, of2.3.0, results, v1706, version |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
circumferential pressure profile on outlet -> error when writing results | mhsr | CFX | 4 | September 1, 2017 05:28 |
Oscillating Airfoil Poor Results at High k (reduced frequency) | dancfd | OpenFOAM Running, Solving & CFD | 3 | November 4, 2013 08:32 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 08:15 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
