natural convection of a 2D plate with bousinesqSimpleFoam
Old   December 31, 2017, 13:13
Default natural convection of a 2D plate with bousinesqSimpleFoam
Marko Josic
emjay is on a distinguished road
Hello everybody,
i have some questions about my case.
As you can see in Drawing.png this simulation is a 2d case.
On the left side is a plate with a uniform temperature T_hot
Every other patch have symmetric boundary condition, except Top and bottom.
I tested some variations of boundary conditions for top- and bottom patch but i couldn't find the right combinations for one specific physical boundary condition.
top and bottom patch should behave like an farfield.
but i don't know which bc should i use for velocity, pressure...
  • velocity should be calculated
  • pressure should be on bottom-patch fixed value
The solver is a bouyant SimpleFoam with Boussinesq approximation.
May somebody can give me a hint.
Best regards
emjay
emjay is offline   Reply With Quote
Old   December 31, 2017, 13:51
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You have to specify in the thermophysicalProperties the dependency of the density of the fluid in dependence of the temperature. It is possible to give a polynom up to 7th grade (plus a constant value).
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   January 1, 2018, 11:36
Marko Josic
Hello Uwe,
thank you for your interest on my problem, but i don't know how your answer match my question.
The question is which boundary conditions for the top and bottom patch are suitable to simulate an "open" boundary condition.
thank you in advance
emjay
Old   January 1, 2018, 11:55
piu58's Avatar
Uwe Pilz
That depensds what you intended for that wall.You may
- set it to the temperature of the fluid volume
- set it to zero gradient
I don't believe that it makes a huge difference.
Uwe Pilz
boussinesqsimplefoam, natural convectin, plate
Natural convection boundary layer simulation over a heated vertical plate camel OpenFOAM Running, Solving & CFD 1 May 9, 2017 01:27
Natural convection on inclined flat plate hakimiqbal FLUENT 0 July 3, 2016 11:48
Natural Convection Off a Hot 2D Plate Droo ANSYS 1 November 6, 2015 17:38
Specifying turbulence parameters for natural convection on vertical flat plate abu250feldman FloEFD, FloWorks & FloTHERM 2 May 5, 2014 14:42
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
