December 30, 2017, 17:02 |
order of solution
Hi Foamers,
when i tried to study mesh independence, i found the papers of Roache, where he defined p as order of the method, which may be obtained by using three grids with constant refinement ratio. I have four questions here: 1- is the term order of solution is different from the term order of accuracy? 2- what define order of solution: a- is it method type FVM or FDM. b- is the solution algorithm SIMPLE or PIMPLE. c- is it the discritization schemes of div., grad., interpolation,.. d- is it the type of solver for p and u. 3- i tried one case with eight meshes with constant refinement ratio of 1.5 a- is it normal to get different p for every field. b- is it normal to get different p for the same field when computed using different three grids from eight grid i have performed "in every time the three grids as successive" . 4- finally, is it possible for the GCI of Roache to increase for one field or more with mesh refinement. thanks, Ahmed |
order of solution, roache |
can you tell me best gradient, pressure & momentum order selection in fluent | sanjiiv | FLUENT | 6 | February 14, 2020 07:07 |
second order scheme problem | hadiso | Main CFD Forum | 3 | November 2, 2016 10:46 |
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 13:29 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 08:51 |
k-omega turbulence model: 1 vs 2 order solution | Manucia | FLUENT | 0 | August 31, 2009 15:57 |
