Print pressure correction matrix coefficients in openFoam
Old   December 26, 2017, 07:33
Default Print pressure correction matrix coefficients in openFoam
AliE is on a distinguished road
Dear Foamers,
I am actually trying to print to screen the coefficients related to the pressure- correction equation in icoFoam (diagonal and off-diagonal). Until now, I have followed the suggestions in this post:
Accessing Coefficient Matrix
Here is the code:
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
label Nc = mesh.nCells(); //Total number of cells
//Diagonal coefficients
for(label i=0; i<Nc; i++)
Info<< pEqn.diag()[i] << endl;
//Off-diagonal coefficients
for(label faceI=0; faceI<UEqn.lduAddr().lowerAddr().size(); faceI++)
Info<< pEqn.upper()[faceI] << endl; //Lower coefficients
Info<< pEqn.lower()[faceI] << endl; //Upper coefficients
It seems to work, but for some reasons in the diagonal coefficents printed out the contribution of the boundary conditions is not included.
Do you have any suggestion to fix my problem?
Thank you very much for the help,
AliE
AliE is offline   Reply With Quote
icofoam, openfoam
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Which pressure OpenFOAM use for incompressible flow? P/rho or (P-101325)/rho ? panda60 OpenFOAM 16 August 14, 2018 05:57
SIMPLE algorithm does not converge when using old pressure (correction) values andreasp Main CFD Forum 3 February 9, 2016 22:18
[blockMesh] Another cylinder question bendel_boy OpenFOAM Meshing & Mesh Conversion 5 January 6, 2015 06:09
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
