chtMultiRegionSimpleFoam not converging
Old   December 26, 2017, 04:51
Default chtMultiRegionSimpleFoam not converging
Shailesh BG
shaileshbg is on a distinguished road
Hello Foamers,
I am working on multi-region heat conduction using chtMultiRegionSimpleFoam.
1) the h residual has decreased below the specified tolerance of 1e-06, see the attached residual plot.
2) the temperature values no longer change with subsequent iterations, see attached temperatures plot.
3) the number of iterations also reduce to zero, see attached iterations image.
4) have tried increasing the nNonOrthogonalCorrectors to 3 to increase the number of iterations per time step, and increased the under-relaxation factor of h to 1
solvers
    h
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.01;
SIMPLE
    nNonOrthogonalCorrectors 3;
relaxationFactors
    equations
        h              1;
but the log file says regions are not converged.
DICPCG:  Solving for h, Initial residual = 5.284098e-07, Final residual = 5.284098e-07, No Iterations 0
- selecting cells using cellZone tumor
- selected 20643 cell(s) with volume 4.159077e-06
Min/max T:301.8466 304.3565
Regions not converged after 300 iterations
ExecutionTime = 56.99 s  ClockTime = 73 s
End
Could anyone please let me know why it is not converging.
Many thanks in advance,
Shailesh
shaileshbg is offline   Reply With Quote
Old   January 1, 2018, 09:45
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Shailesh,
Happy New Year!
I would say your result is converged. All the metrics you showed indicate that it is converged. I do not recall ever seeing the remark in the log about convergence with any SIMPLE solver, only with the PIMPLE solvers.
Some questions that may help you get conclusions:
Did you check the results visually?
Did you use some particular functionObject that could cause this remark?
Regards,
Tom
tomf is offline   Reply With Quote
Old   January 3, 2018, 08:31
Shailesh BG
Hi Tom,
Thank you for your reply and a very happy new year to you.
I managed to get the solver to converge by using residualControls, here is a snippet of my fvSolution
SIMPLE
   residualControl
        h
            tolerance 1e-6;
            relTol 0.1;
Now I get converged solutions.
Warm Regards,
Shailesh
chtmultiregionsimpefoam, convergence, residuals, temperature calculation
acceptable converging? wales FLUENT 8 January 19, 2016 03:39
My steady state solution converges for a while but stops converging C.C Fluent UDF and Scheme Programming 0 October 9, 2013 12:11
NACA0015 Pressure Coefficient Converging Problem lampe1234 STAR-CCM+ 0 September 15, 2013 16:43
Converging Diverging Nozzle in OpenFOAM danishdude OpenFOAM Running, Solving & CFD 1 September 15, 2012 01:12
transient converging, but not steady PHS- FLUENT 5 July 25, 2011 15:25
