December 24, 2017, 03:01 |
Only radiation validation problem
Jung da yoon
Rep Power: 9 |
HI all
I am trying to make only radiation solver, so far with little success. Here are the codes. 1. radiation.C Code:
\*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "radiationModel.H" #include "simpleControl.H" #include "fvOptions.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFvOptions.H" #include "initContinuityErrs.H" #include "createControl.H" Info<< "Reading Temperature field\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); autoPtr<radiation::radiationModel> radiation ( radiation::radiationModel::New(T) ); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; { radiation->correct(); } runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } Code:
radiationFoam.C EXE = $(FOAM_USER_APPBIN)/radiationFoam Code:
EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/sampling/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \ EXE_LIBS = \ -lfiniteVolume \ -lfvOptions \ -lsampling \ -lmeshTools \ -lfluidThermophysicalModels \ -lspecie \ -lradiationModels \ -lmeshTools I have tried Fvdom radiation model and finally I want to know heat flux on walls. I have attached the following case named Enclosure. Problem : 1. I don't know if only radiation solver is correct. So plz tell me errors or bugs 2. I want to know heat flux on walls. As a result of paraview program, I think 'qin' means 'heat flux on walls'. Is it correct? 3. After running this case with paraview, I checked that qin of front and back walls is different from other walls. Why it happens ?? I'm very confused with only radiation solver and case. Plz help me !! Happly christmas Last edited by kane; December 25, 2017 at 00:38. Reason: Adding information+ |
February 3, 2018, 20:25 |
Jaydeep
Rep Power: 11 |
Hi Kane,
If you want to solve radiation only -- I would recommend using any of the heat transfer solvers. For e.g. you can pick up buoyantSimpleFoam, and turn "FrozenFlow" on in fvSolution. It will stop mass momentum equations and will only solve energy. p.s. I used the same approach with chtMultiRegionSimpleFoam |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 06:43 |
How to rewrite a standard OpenFOAM solver as a C++ class | cfbaptista | OpenFOAM Programming & Development | 7 | March 23, 2016 05:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
