simpleFOAM - internal pipe flow - meanVelocityForce |
#1 | |
Guilherme
Rep Power: 10 ![]() |
First, I'm using OpenFOAM 5.0 (komegaSST), all my settings is attached below. Re = 5300 (R = 0,006035 - L=5D) Has anyone used meanVelocityForce (fvOptional) yet? I am conducting a study on internal pipe flow using simpleFoam solver. The velocity (there is a demo image inside the attached file) in the center of the pipe drops dramatically after 1000 iterations. Could anyone share experience? I believe this fall affects Reynolds's number and compromises the results of my simulation ... I would really like to keep constant velocity. And I would also like opinions about the convergence of my model, I believe that the process is very slow, since in the literature, a case similar to mine, occurred convergence in 1200 iterations. Thanks For (y + ~ 1) and according Tobi, I set my settings: Quote:
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Simulating internal & external pipe flow simultaneously | 30na | FLUENT | 0 | March 11, 2015 11:44 |
Problems with simpleFoam with flow in pipe | fsalvucci | OpenFOAM | 6 | April 17, 2012 08:31 |
internal flow and external flow ? | Pathway0320 | FLUENT | 1 | November 17, 2006 03:37 |
