Deleting files in /constant/polyMesh to reset and store OpenFOAM case
Old   December 21, 2017, 08:37
Default Deleting files in /constant/polyMesh to reset and store OpenFOAM case
Alwin
sdfij6354 is on a distinguished road
I have a case with the following files in /constant/polyMesh
- Boundary
- cellLevel
- cellZones
- faces
- faceZones
- level0Edge
- neighbour
- owner
- pointLevel
- points
- pointZones
- refinementHistory
- surfaceIndex
I'm using blockMesh, snappyHexMesh and topoSet to create my mesh, consisting of a 3D-Geometry in a 3D domain with multiple refinements.
Which of the files in the above folder can I safely delete when storing the case for later use? Keeping the files requires a lot of storage.
I've tried deleting all files and only keeping "boundary", but re-creating and running the case with the same previously used commands and settings is not successfull. I get a different convergence result compared to the original case. Furthermore, the re-created mesh differs from the original mesh (e.g. layering around geometry).
Best regards and thank you for any help,
Alwin
sdfij6354 is offline   Reply With Quote
