rhoPorousSimpleFoam error in thermophysical properties |
adibansv
Rep Power: 9 ![]() |
i tried to run the default case files with new mesh but it is throwing some error in thermopysical properties.can anyone please help me???/?
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { nMoles 1; molWeight 28.96; } thermodynamics { Cp 1004.5; Hf 0; } transport { As 1.458e-06; Ts 110.4; } } // ************************************************** *********************** // /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : rhoPorousSimpleFoam Date : Dec 20 2017 Time : 22:52:26 Host : "adibanshaan-X550JX" PID : 6210 Case : /home/adibanshaan/openfoam/tutorials/compressible/rhoPorousSimpleFoam/rho nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.001 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } #0 Foam::error: ![]() #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heThermo<Foam::rhoThermo, Foam: ![]() ![]() #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam: :heRhoThermo<Foam::rhoThermo, Foam: ![]() ![]() #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMe sh const&, Foam::word const&) at ??:? #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
heat transfer simulation in a tube with the variations of thermophysical properties | Gary51075607 | OpenFOAM | 0 | January 12, 2015 08:36 |
confused with units in solidThermophysical properties and Thermophysical properties | zahraa | OpenFOAM Running, Solving & CFD | 3 | August 14, 2014 08:11 |
table properties for thermophysical properties | romant | OpenFOAM Running, Solving & CFD | 1 | August 12, 2014 08:41 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
