oversetmesh with 6 DOF in v1706
Old   December 20, 2017, 10:35
Default oversetmesh with 6 DOF in v1706
shota sasaki
fluidpage is on a distinguished road
Hi, I am new here.
I started to use OpenFoam v1706 one month ago in order to simulate the movement of the 3D object under the force of the fluid.
I tried it using pimpleDyMFoam but mesh deformation is too big to simulate.
So now I am working on it by using oversetmesh function.
I ran some tutorials about oversetmesh but I could not use oversetmesh(overPimpleDyMFoam) with 6DOF.
How can I use oversetmesh with 6DOF?
fluidpage is offline   Reply With Quote
Old   December 21, 2017, 05:21
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi, look at this tutorial case:
$FOAM_TUTORIALS/multiphase/overInterDyMFoam/floatingBody
That one uses 6DoF with overset.
Regards,
Tom
tomf is offline   Reply With Quote
Old   December 21, 2017, 17:44
shota sasaki
Hi, Thank you for reply.
I could not run the tutorial due to the error below when I use overInterDyMFoam.
—> FOAM FATAL IO ERROR:
This code should not be executed by someone with administrator rights due to security reasons.
(it writes a shared library which then gets loaded using dlopen)
file; /home/Desktop/openfoam-plus/tutorials/floatingBody/background/constant/dynamicMeshDict.sixDofRigidBodyMotionCoeffs from line 30 to line 30.
From function static void Foam::dynamicCode::checkSecurity(const char*, const Foam::dictionary&)
in filedb/dynamicLibrary/dynamicCode/dynamicCode.C at line 65.
I use the Openfoam v1706 in docker, how can I avoid this error?
It seems that I can start docker as superuser only.
and I would like to simulate the movement of a complicated shape object placed in the water flow. Is it possible to use the snappyHexMesh to make case of oversetmesh, and give a uniform flow in overInterDyMFoam?
Old   December 21, 2017, 18:16
Tom Fahner
I would not know how to help you with this. Maybe someone else with more experience on Docker/OpenFOAM on Windows can help you with this. It souns like a configuration error, but as I only run natively in Linux I can not help you.
Best of luck!
Regards,
Tom
Old   June 12, 2020, 12:21
TAKILT said
TAKILT said is on a distinguished road
Originally Posted by fluidpage View Post
Hi, I am new here.
HI,
I want to do the same as you, have you managed to use 6Dof with Overset???
best regards
TAKILT said is offline   Reply With Quote
6dof, overpimpledymfoam, oversetmesh
Six DoF - Overset in OpenFOAM ddemiroguzhan OpenFOAM Running, Solving & CFD 1 January 24, 2019 06:36
Force can not converge colopolo CFX 13 October 4, 2011 23:03
The concept of DOF in fluid mechanics and CFD bearcat Main CFD Forum 8 May 27, 2007 19:02
help required in using six dof solver in fluent Shah FLUENT 1 February 25, 2006 12:31
Six dof UDF Dr. John Anttonen FLUENT 0 February 22, 2002 15:47
