Sebastian
Rep Power: 9 ![]() |
Dear community,
I am currently trying to simulate a flow in a periodic domain. The periodic structure consists of (parts of) cylinders. ![]() ![]() For meshing the geometry I am using snappyHexMesh with a stl-geometry file. I am using the boundary conditions as explained here: Periodic Inlet/Outlet Boundary Condition Thus I try to prescribe a mean velocity (in x-direction) and want to obtain the pressure loss over the periodic structure. I thought that the flow in x-direction is periodic, i.e., inflow = outflow in the periodic domain. However, when I duplicate the domain in paraFoam, the flow profile at inlet and outlet is not the same. ![]() As one can see there is a discontinuity between the two parts of the periodic domain. Am I wrong to expect continuity of the velocity? The pressure drop looks OK. Attached you find my files for executing the case. Maybe someone of you can have a look if everything is correctly set up. If some more data are needed, please tell me. Thank you in advance for your answers and your help. Regards Sebastian ![]() |
Periodic Pipe Flow LES | dvolkind | CFX | 8 | March 21, 2020 05:30 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
pressure gradient of a 2D periodic flow problem | Honey | FLUENT | 1 | October 17, 2012 06:06 |
Periodic boundary in unsteady flow | ac2011 | FLUENT | 0 | September 26, 2011 06:52 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
