December 12, 2017, 01:13 |
How to remove this openFoam error
Taoyuan
I have run the case using openFoam, but showing scalar error
Capture.PNG please see this attachment Please give me your suggestions to rectify this error |
December 12, 2017, 04:52 |
Look at Courant number, your simulation is diverging (and with the information, you have posted it is almost impossible to tell the reason). |
December 14, 2017, 13:13 |
Quick advice
#3 | |
Dominik Pöltl
Rep Power: 13 |
Without deeper knowledge, here's some quick advice (1 or 2 or 3):
Yeru |
December 14, 2017, 17:23 |
Aäron Thijs
Rep Power: 10 |
The useful OpenFoam advice has already been given in the previous two posts. I just wanted to add some more info and an explanation about the error itself.
What seems to be happening, as also stated previously, is that the simulated values explode, due to what seems to be a large time step of 0.005s. This causes the Courant number to be way too large. The two first points of advice Yeru gives basically do the following:
December 14, 2017, 22:24 |
Taoyuan
Thank you so much
openfoam, scalar error |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
