December 7, 2017, 11:26 |
FanPressure BC direction reversal
Matt Houchin
Rep Power: 9 |
Hi FOAMers,
I am trying to set a fanPressure boundary condition within a ducted fan, using the createBaffles function to create two patches within a ducted fan casing. I have created the baffles and assigned them as fanPressure boundaries in the p initial conditions as such: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | |*---------------------------------------------------------------------------*| |* OpenFOAM for Windows 16.06 (v1) *| |* Built by CFD Support, www.cfdsupport.com (based on Symscape). *| \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { atmosphereBoundary { type fixedValue; value uniform 0; } ductWork { type zeroGradient; } fanCasing { type zeroGradient; } plenumWall { type zeroGradient; } systemBoundary { type fixedValue; value uniform 0; } fanOutlet { type fanPressure; fileName "fanCurve"; outOfBounds clamp; direction out; // in | out p0 uniform 0; value uniform 50; gamma 0; } fanInlet { type fanPressure; fileName "fanCurve"; outOfBounds clamp; direction in; // in | out p0 uniform 0; value uniform -50; gamma 0; } } Regards, Matt |
December 11, 2017, 09:42 |
Matt Houchin
Rep Power: 9 |
All,
I have found a solution to the above problem in case you are looking for a solution... The direction of the fan can be switched by reversing the actions.sourceInfo.options variable from master to slave in the toposet dict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name fanSource; type faceZoneSet; action new; source searchableSurfaceToFaceZone; sourceInfo { surface triSurfaceMesh; name baffle_1.stl; } } { name fanSourceSlave; type cellSet; action new; source faceZoneToCell; sourceInfo { name fanSource; option slave; } } { name fanSourceFace; type faceZoneSet; action new; source setsToFaceZone; sourceInfo { faceSet fanSource; cellSet fanSourceSlave; } } ); // ************************************************************************* / / |
ERROR: Flow direction on the boundaries must not be tangential to the boundary. | turbomax | CFX | 3 | October 27, 2024 07:19 |
fanPressure BC | pingat | OpenFOAM Running, Solving & CFD | 0 | November 8, 2013 03:52 |
Changing inflow velocity direction deteriorates lift and drag | ziggo | FLUENT | 3 | July 24, 2013 09:39 |
[ICEM] Changing edge direction | la7low | ANSYS Meshing & Geometry | 2 | June 7, 2010 14:26 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
