Rep Power: 0 ![]() |
Dear Foamers,
I am new in OpenFOAM simulation. Recently, I am building a numerical wave flume by using OLAFOAM library, to simulate the motion of a wave energy converter (olaDyMFoam). The flume works well. But when I add a function to the controlDict to run-time sample alpha.water at fixed points, the solver "olaDyMFoam" only runs 9.7 sec and then stop updating the log file (log.olaDyMFoam). The odd thing is, this job will be still running until timeout without any errors. I use OpenFOAM-3.0.1 and my job was calculated on a cluster. The controlDict setting is listed below. Many thanks for your help. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 3.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application olaDyMFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 240; deltaT 0.1; writeControl adjustableRunTime; writeInterval 0.05; purgeWrite 0; writeFormat ascii; writePrecision 12; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo .5; maxAlphaCo .5; maxDeltaT 0.02; functions { waveElevation { type sets; functionObjectLibs ("libsampling.so"); setFormat raw; interpolationScheme cellPoint; outputControl outputTime; // Don't use timeStep outputInterval 1; sets ( Probe_50m { type uniform; axis z; start (50 0 2); end (50 0 -2); nPoints 401; } Probe_100m { type uniform; axis z; start (100 0 2); end (100 0 -2); nPoints 401; } ); fields ( alpha.water ); } }; libs ( "libwaveGeneration.so" "libwaveAbsorption.so" "libsampling.so" ); |
Pablo Higuera
Rep Power: 19 ![]() |
Hi Chubo,
I have faced this problem too. This is caused by a limitation of OpenFOAM sampling procedure. From what I remember, as the time and mesh deformation progress, the initial sampling points that were inside a given cell will belong to another one (or even to a face, which is less likely, but has also happened to me), and sampling will fail. I suggest that you open a bug in the OpenFOAM system to see if they can do something to update the points at runtime for 'DyM' solvers. https://bugs.openfoam.org/rules.php Best, Pablo |
Hi Pablo,
Thank you for your information. Not sure the problem will be solved if I change the interpolationScheme from 'cellPoint' to 'cellPointFace'. I will let you know the result. Regards Chubo |
olafoam, sampling, solving |
icoFoam Courant number growth problem | tdof | OpenFOAM Running, Solving & CFD | 12 | May 24, 2023 14:00 |
OF23x: const labelList& cZone() and const cellZone& cZone() not working | A_Pete | OpenFOAM Programming & Development | 2 | October 24, 2014 04:47 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
Getting too many iterations by velocity solving (aborting). Changing U - Solver? | suitup | OpenFOAM Running, Solving & CFD | 0 | January 20, 2010 07:45 |
