Running a turbulent case by using a laminar solution
Old   December 5, 2017, 00:29
Default Running a turbulent case by using a laminar solution
TWB
quarkz is on a distinguished road
I have been trying to run a hypersonic double cone problem with turbulence modelling. Using komega-sst, the omega diverged after 3-4 time steps. I changed to another model and the same thing happens. So I tried to run my case using my previous laminar solution, which completed w/p problem.
To reach steady state, I ran until t=0.005 in the laminar case. So I tried to use the laminar solution at t=0.0002 to start my turbulent case, and let it run till 0.005.
Is this a reasonable or correct way to simulate a turbulent case?
Another online study suggested running at a low Re 1st, then increasing the Re to the actual one as time proceeds. Is that ok too?
Thanks.
quarkz is offline   Reply With Quote
Old   December 5, 2017, 10:47
Lucky
Both are okay. I would think the laminar solution is preferred over the solution at wrong Reynolds number. I don't get why you don't use the lastest laminar solution as the initial condition for your turbulent case.
A better solution though is to try and figure out what set of schemes is making it blow up, assuming it's not something simple like providing the correct initial k and omega fields.
Old   December 6, 2017, 01:56
TWB
Hi LuckyTran,
Thanks for the reply. My case converges to a steady solution. So I thought that if I start with a laminar steady solution, the new turbulent steady solution may be too similar to the laminar one.
I already tried to mix different schemes, like upwind etc. However, it still blows up. There are simply too many possible combinations and I have tried quite a few. Hence, I decided to use this mtd. It seems to be working (not diverging) but I have yet to anaylze the results.
Old   December 6, 2017, 18:04
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
I always use the same approach when I have problems with stability. I start with a case with a lower Reynolds and increase the Reynolds little by little. The big problem with CFD in general are the BC and IC. With turbulence models this becomes more important.
juliom is offline   Reply With Quote
Old   December 6, 2017, 21:43
TWB
Hi juliom,
I'll try your mtd too. Thanks!
Laminar vs Turbulent Navier-Stokes truman Main CFD Forum 8 July 10, 2017 08:20
Wrong adjoint solution ONERA M6 euler test case JanH SU2 6 March 6, 2015 12:58
[GAMBIT] 3D Boundary Layer Laminar and Turbulent meshing Harald D ANSYS Meshing & Geometry 1 July 7, 2009 07:20
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 14:40
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
